The power button does not work at all. The short or long press does not change anything.
[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Best having a remote with a learnable IR power button
mine was like £7.50
Originally posted by tillaz87 View Post
All I can suggest is reading the minix forum I posted it's about making the remote work on other boxes but since its IR code to turn on is hard coded to bootloader it's kind of pointless anyway as you will never be to turn the box on with it.
mine was like £7.50
Thank you very much for your help .what is the brand and model of the remote control you use?
Hi tillaz87,
I tried your ROM for the first time. I'm on it for 3 days. So far it's really good experience. Just wanted to thank you and appreciate your work. I switched mainly for 60fps YouTube but surprised to see how snappy the overall experience is.
One clarification. Page 1 you had mentioned ad block for YouTube. I am still getting the ads. Did you remove it for some reason? Are there apps that can block YouTube ads?
Thanks once again m8!!
Thanks once again m8!!- Hosts restored (if want to block ads use this)
or
Add blocking from 10.5 is here, flash in recovery OldAddBlockig.zipAttached Files
Originally posted by tillaz87 View Post- Hosts restored (if want to block ads use this)
or
There are currently 3002 users online. 0 members and 3002 guests.
