[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tillaz87 View Post
Have you tried flashing the patch first?
Originally posted by Novato View Post
Yes, it resulted in the first error I mentioned, simply bluetooth did not start, I realized that the file * libbt-vendor-qcom.so * has no utility on my device, on the contrary would make Wi-Fi turn off. What I did was erase this delete this file and just keep the "libbt-vendor.so", with that now the bluetooth and wi-fi are work at the same time, however the audio bluetooth is slow and lagging. I posted a question for Magendaz on the topic of M8S Pro, but it has been days since it did not respond there.
Hello,
I have Beelink GT1 Ultimate and just yestreday installed this great ROM version 10.6.
One problem I'm experiencing is with Netflix, I get error ui-800-3 (207003) which indicates an Hardware problem.
I was able to Run Netflix with the Original ROM of the device.
Is there any solution for this issue?
Netflix apk here (Netflix 6.0.0 build 27149)
ALL here https://www.apkmirror.com/apk/netflix-inc/
hi, test done with 708NO with your patch works fine. The difference with 10.7 is seen. LA 10.7 is as smooth as oil, a pity for the two problems that I find in my box: if I could fix the bug usb camera, and 4k resolution in this case in my box just kodi part I disconnected from the TV and I am forced to unplug and hang up. then it's perfect, thanks for your work
Originally posted by josephmk View Post
Thanks Tillaz87. I will try it and post the results here.
I tried this fix. Now I'm unable to switch ON the Bluetooth. I know you don't have the device to try.
Request anyone else on 9377 to help if they are able to get Bluetooth working smooth.Thanks.
My goal was to make it available to anyone who needs it, but I was without internet for a few hours. I will post the correction in a post below, as I have not yet had time to upload, the internet has just returned.
All I did was reinstall the Shiningworth firmware from Magendaz, find the fixes it released and apply to its firmware, in the end it was very easy, lol.
Bluetooth Fixer Tested on Mecool M8S Pro with Chip Wifi/BT Longsys LMT8830.
As promised, here is the fix for devices with wifi chip LMT8830 that is experiencing stuttering in audio when connecting bluetooth devices.
This chip though is not known by many, but the LTM8830 is a highly integrated and excellent performance Wireless LAN SDIO network interface device.
This module design is based on the Qualcomm Atheros QCA9377-3 chipset is a single-chip wireless local area network (WiFi) and Bluetooth.
Download: BT Fixer for Mecool MS8 Pro and LMT8830 Devices.
Thanks To: Guest by fix on Shiningworth Firmware and tillaz87 by support and scripts for TWRP flash.
Originally posted by Novato View PostBluetooth Fixer Tested on Mecool M8S Pro with Chip Wifi/BT Longsys LMT8830.
must of been when I was adding the additional AP6533 drivers. i'm going to update to add that back
There are currently 1257 users online. 0 members and 1257 guests.
