[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tillaz87 View Post
Originally posted by Novato View Post
Exactly both, initially I edited the file "Vendor 2319 ... 0010.kl" but at some point stopped working, I looked for this alternative that is to change the key in the file "Generic.kl". I also used the terminal to make sure. My Air Mouse is a sikilar to the one of the forum below:
Originally posted by X92-2GB View Post
Just an oddity with editing... all you need is one space or invalid character, and you break a config file's function. Had that happen with wifi net config file. Had to use a backup, as everything looks good, but unable to see the error without comparing with a more robust editor.
On.. ha I made all the sysmlink in the updater-script for WiFi drivers with capital S for system..
Took me ages to click why it wasn't working as I knew the code was right
Attach the .kl you made I will have a look and add it to any future patch
Exactly, the worst and I am just a noob who likes to venture from time to time, I can really say that I do not know exactly well I did.Attached Files
Could try this
I started editing and with no results, I remembered that I had at some point replaced the file "Remote.conf" so I decided to reinstall the firmware from scratch through my memory card.
It took me about two hours to realize that my efforts were going low because I had forgotten to put the 2.4G Air Mouse Dongle. lol. After that I saw that your patch works.
However, in the same way as I described in the first paragraph. So I started editing, and I saw that nothing I did was producing results. That's when I discovered the secret of everything!
If I delete a line or something important is modified the file "Vendor.kl" is invalidated and the file "Generic.kl" is started to function as a substitute. That was all I needed to know!
Since then I have managed to map 97% of the buttons on my keyboard, my expectations are to map shortcuts to the Netflix, MX Player, Google Play, Sideload Launcher and Settings APP.
however some things like Home button was disabled, the Home function was present in the Menu button.
2) Download and install this app. and open it.
Code:key ?? SETTINGS key ?? EXPLORER key ?? KODI key ?? VIDEO_PLAY key ?? ALLAPP
Hey tillaz - been with you since v7 so appreciate the work yuo have done.
downloaded and installed the original 10.7 a few days ago, signed in and that was about it, didn't get chance to test it.
spotted earlier that you had updated 10.7 so d/l the image again.
using usb Burning Tool 2.0.8 tried loading the updated image but I get the famous romcode/initialize ddr/....... fault.
its a long time since I had this error and my way round it was to load image to usbBT, connect box then put power to box before pressing start and this has worked fine for months.
so uninstalled 2.0.8 and tried 2.0.9, restarted laptop, no success, d/l image again and tried both 2.0.8 and 2.0.9 again and still no joy
any ideas mate.
Originally posted by verseau71 View PostHello tillaz87 Your ROM is impeccable is it possible to implement a SAMBA server in the GT1 Ultimate Thanks for your help
There are currently 1602 users online. 0 members and 1602 guests.
