[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Hi, thanks for you work
This rom is very good, but there are some little issues for me:
-android tv remote control app don't work(i have no idea on how to fix)
-some keys of my keyboard don't work(i think i can fix using the post/guide linked on mainpost)
-this rom uses only 2 gb(i have 3 gb variant)
Anyone can help me on 1° and 2° issue?
Do you think i have to use another rom compatible with 3gb ram?
You can test this by flashing the stock Beelink ROM and then install Fill Ram from the playstore.
What should happen is Fill Ram will fill the RAM to over 90%, and show on screen that RAM is low but will keep running.
On my 706DO GT1 Ultimate with fake RAM it won't fill past 62% before the Fill Ram app closes and it doesn't even show on screen that memory is low.
Originally posted by Winno View Post
You may have a GT1 Ultimate with fake RAM where it reports that it has 3GB but it really only has 2GB.
On my 706DO GT1 Ultimate with fake RAM it won't fill past 62% before the Fill Ram app closes and it doesn't even show on screen that memory is low.?
Thanks, what about android tv remote?
Originally posted by tillaz87 View Post
it should work unless your BT is broke or you removed GooglePlayServices
Originally posted by testphase View PostMy gt1ultimate always freezd with this ROM, especially when using YouTube. Android 6.0 Roms works OK, very strange
No, the very first batch with 6255 chip, it freezes mostly when I use video streaming apps, not only youtube, the ATV 6.0 rom from superceleron works great, maybe is the Android 7.0 issues
Mine is A912 and this works well for me and lots of other s912, infact your the first to report this over the whole 176 pages.. without a logcat though, its impossible to know why your box has issues
after crash/freeze I would need
adb logcat *:W -d > logcat.txt
There are currently 2711 users online. 1 members and 2710 guests.
