[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
tillaz87
I just switched to your ROM in order to try and fix some bugs i had with the superceleron one and it worked great, I now have youtube 4k and europsort player working, which were the 2 major bugs i had with previous rom, so thanks for the work !
But i have one little issue with your rom, i use a i25 rii mini remote wihich has an azerty layout (i'm french) but when i use the keyboard of the remote it acts as a qwerty one and I can't seem to find where to change that. Is there anyway to change it ?
MOD - Air Mouse MX3 + Remote Control + New Wallpaper
Hello everyone! First of all I want to thank tillaz87 7 for all the support he has given me. Thanks man! Next I want to share some things with you. Come on, since yesterday I am silent in the forum because I spent this time tweaking my TV Box, I know this is kind of fanaticism, but I like to commit and sometimes.
Well I was finally able to completely map my air mouse to what I needed, it was several hours of editing, the worst part was waiting for the TV Box to restart every time. In addition to the mapping file I will also leave attached two apps to modify the TV interface, if you want to leave attached at the end of the post.
That is, the .kl file should work for most mx3, mx, and similar controls, or at least that's my expectation. If yours is not the same you will have to edit if you want something similar. In order to start Netflix, Google Play, File Explorer and the Screenshot function, I used the Button Mapper app, which you can find on Google Play to download.
To achieve the same results as me, regardless of the remote or air mouse you have just follow the images available for downloads below. The MX3 Key Remapping zip can be installed by TWRP, but if you do not have this control template, it is not interesting that you are installing this.
The other zips must be unzipped, applications can be installed as an update. And Screenshots are a step by step, follow the pictures.
Download: MOD Apps - Screenshots - MX3 Key Mapping - Button MapperLast edited by Novato; 13 April 2018, 18:09.
Originally posted by tillaz87 View Post
That icon on the shield tv is for pairing shield accessory's lol sorry couldn't resist
cool mods though nice to this kind of thing from other users
There are currently 2465 users online. 1 members and 2464 guests.
