Excuses, I'm Brazilian and the automatic translation leaves doubts
[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by DhiJay23 View Post
Thank you for all your time, effort and the hard work you put into this ROM. We are greatly appreciate what you did to make our box to ran to its full potential, Thank again. One quick question? Will you make a custom rom for ShieldTV?
Originally posted by craser View Posthi, 10.7 usb camera is not fixed. 4k resolution with spmc gives me a black screen. do you have any fixes? h96pro plus. thank you
tested all that before I uploaded.
try turning the auto frame stuff off
camera could be anything sorry probably broke with android tv stuff
Also I would like to add to anyone asking about 4K HVEC 10BIT
I tested the 400mbs jelly fish file and it could not run smoothly because my sdcard and USB storage device are simply not able to read fast enough you can see this by looking at the buffer it needs 400mbs once it gets ahead of the buffer is slows down / lags
same issue on my shield tv with the USB device
Not tried on internal nand storage yet it should be faster though
Originally posted by tillaz87 View Post
flash in twrp [ATTACH]n718761[/ATTACH]
All I can suggest http://freaktab.com/forum/tv-player-...-and-optimized give it a try.
This is deodexd stock apk are not so you might of missed the oat folders from stock
flash in twrp [ATTACH]n718762[/ATTACH]
and once again, thank you for all your hard work and this final release, I'm having a very good experience with it
Originally posted by tillaz87 View PostDiscontinued April 9th 2018, For me this is stable, but no longer have the time for his so moving on from here.
Recant Changes: v10.7 Final release (To be taken as is)- built Magisk root method in to TWRP (Advanced/Magisk root)
- Fixed TWRP reporting 5.1.1 OS, some zip like xposed fail because of this
- Busybox updated / fixed
- reverted some lib stuff
- Fixed auto frame settings?
- USB Camera fixed?
I will most likely continue to reply in this thread for now.. but will be giving my GT1 to a new owner since I have the shield tv again
maybe I will be back when next gen amlogic boxs come about, if i'm sent one.
Hi tillaz87, congratulations for your effort and hard work over this time with the GT1 and similar hardware devices! A few minutes ago I installed the 10.7 firmware on the device and loved it all. The only thing I want to change and the ratio of pixels per inch (dpi), since my monitor has a 22 "screen, it does not make sense to leave the aspect ratio high.
But I came up with a recurring problem, something I had previously faced with installing the ATV ROM for Vorke Z6. The error itself is related to bluetoothh, and makes Wi-Fi hang up when a Bluetooth device is connected to the Box TV. The Wi-Fi chip on my device is the LMT8830 which is very similar to Qualcom's QCA9377.
I'm not quite sure but maybe it's something similar to what Magendaz has fixed in a test with the Shiningworth All-in-One firmware for us from M8S Pro. My question is whether it's easy to run this or requires a little more habiliity and knowledge to perform the proper repairs. Link where Magendaz describes the error below:
http://freaktab.com/forum/tv-player-...384#post706384
I already made a BT patch based of that info but are kernel was updated. so not sure if it still needed as my box is AP6255
http://freaktab.com/forum/tv-player-...147#post717147
Android TV and its apps are mainly built for 320dpi you can change to 240dpi but will see some graphical abnormality.
Thanks, I'm testing here but the initial instructions (remove libbt-vendor.so and then rename libbt-vendor-qcom.so) just disabled Bluetooth. I tried to download your fixer but it is no longer available.
Hi, I've made a little progress, but I think I know how to solve it now. I did the following, returned the libbt-vendor.so file, did the permissions, removed the libbt-vendor-qcom.so file, and rebooted the device. Initially the bluetooth box plugged in but this triggered the wi-fi shut down. I turned on the Wi-Fi again and it worked, the two are connected but the audio got choked. I believe that if I use the same libbt-vendor.so file that Magendaz used in its last build Shiningworth the audio is corrected. Too bad I'm going to need to change the system because I can not unpack this type of system. Unless you tell me what prohamap to use. xD
Originally posted by Novato View PostI believe that if I use the same libbt-vendor.so file that Magendaz used in its last build Shiningworth the audio is corrected. Too bad I'm going to need to change the system because I can not unpack this type of system. Unless you tell me what prohamap to use. xD
I could just included the old boot.img with the BT patch which would guarantee it works like it used to.
There are currently 1238 users online. 1 members and 1237 guests.
