btw do you have any idea if Ugoos AM3 firmware would work for tv-boxes with 3GB DDR4 RAM ?
[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tillaz87 View Post
Not sure all i know is it only supports QC9377 WiFi
I flashed it and used with Ethernet but nothing about it interested me as my experience is better with af off never looked at device tree
I have installed xperia keyboard and the problem with ENTER key is gone. I am also disabling USB with this script (in init.d)
Code:~ # cat /system/etc/init.d/00-usb #!/system/bin/sh (while true; do #wait for sleep if [ wake=`cat /sys/power/wait_for_fb_sleep` ]; then date >> /data/local/sleep.txt #disable devices connected to two usb ports if any if [ -d /sys/devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-1 ]; then echo 0 > /sys/devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-1/bConfigurationValue fi if [ -d /sys/devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-2 ]; then echo 0 > /sys/devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-2/bConfigurationValue fi fi #wait for poweron/boot/reboot if [ wake=`cat /sys/power/wait_for_fb_wake` ]; then #enable devices connected to two usb ports if any if [ -d /sys/devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-1 ]; then echo 1 > /sys/devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-1/bConfigurationValue fi if [ -d /sys/devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-2 ]; then echo 1 > /sys/devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-2/bConfigurationValue fi fi done &)
Originally posted by zyxmon View PostI have installed xperia keyboard and the problem with ENTER key is gone. I am also disabling USB with this script (in init.d)
if you use the keytest.apk and give me the scanodes for each button press I can add proper support for it
tillaz87 - I'll post scancodes later. Thanks. One more remark. wget busybox applet from /system/xbin downloads truncated or corrupted files from nginx servers. There is a bug in busybox 2.26.2 that was fixed later. Can you replace it with another busybox? This one is OK - https://play.google.com/store/apps/d...meefik.busybox (it can also be downloaded from https://github.com/meefik/busybox/releases ). It look like applets in /system/xbin are just hard copies of busybox binary, not even hardlinks (or softlinks). Is it correct?
Originally posted by zyxmon View Posttillaz87 - I'll post scancodes later. Thanks. One more remark. wget busybox applet from /system/xbin downloads truncated or corrupted files from nginx servers. There is a bug in busybox 2.26.2 that was fixed later. Can you replace it with another busybox? This one is OK - https://play.google.com/store/apps/d...meefik.busybox (it can also be downloaded from https://github.com/meefik/busybox/releases ). It look like applets in /system/xbin are just hard copies of busybox binary, not even hardlinks (or softlinks). Is it correct?
its not a proper fix though, the ENTER key for a keyboard should not really be mapped to the ok/select button.
I have obtained scancode of enter button - it is 28. Mapping it to DPAD_CENTER or ENTER does not help in case of leankey keyboard, as it was previously checked.
if its just a keyboard+mouse its not compatible with the ATV keyboard, The guide is only for remote and gamepad
ENTER button should be ENTER on a keyboard, use Gboard or any other keyboard for phone
tillaz87, thank you for the great rom, it looks very stock looking
I'm trying to use it without google apps, which require ExtShared and ExtServices (GoogleExtShared and GoogleExtServices requires gmscore, therefore cannot be used without gapps). I pulled em out from Vorke firmware and put it on your rom, and it was giving me errors... Is it possible to know correct firmware that I can pull out system apks that works on your rom?Last edited by NoOneOth; 03 April 2018, 19:12.
There are currently 1956 users online. 2 members and 1954 guests.
