[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
One new question - I have logitech keyboard+mouse connected to usb
Code:~ # cat /proc/bus/input/devices I: Bus=0010 Vendor=0001 Product=0001 Version=0100 N: Name="aml_keypad" ...... ...... I: Bus=0003 Vendor=046d Product=c534 Version=0111 N: Name="Logitech USB Receiver" P: Phys=usb-xhci-hcd.0.auto-2/input0 S: Sysfs=/devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-2/1-2:1.0/0003:046D:C534.0001/input/input3 U: Uniq= H: Handlers=kbd event3 B: PROP=0 B: EV=120013 B: KEY=1000000000007 ff800000000007ff febeffdfffefffff fffffffffffffffe B: MSC=10 B: LED=1f I: Bus=0003 Vendor=046d Product=c534 Version=0111 N: Name="Logitech USB Receiver" P: Phys=usb-xhci-hcd.0.auto-2/input1 S: Sysfs=/devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-2/1-2:1.1/0003:046D:C534.0002/input/input4 U: Uniq= H: Handlers=kbd mouse1 event4 B: PROP=0 B: EV=1f B: KEY=3007f 0 0 483ffff17aff32d bf54444600000000 ffff0001 120f938b17c000 677bfad941dfed 9ed68000004400 10000002 B: REL=1c3 B: ABS=100000000 B: MSC=10
Code:# ls -al /system/usr/keylayout drwxr-xr-x 2 root root 4096 Apr 1 21:33 . drwxr-xr-x 8 root root 4096 Dec 21 11:45 .. ...... -rw-r--r-- 1 root root 2793 Dec 21 11:45 Vendor_046d_Product_c532.kl -rw-r--r-- 1 root root 1251 Apr 1 21:31 Vendor_046d_Product_c534.kl -rw-r--r-- 1 root root 9191 Dec 21 11:45 Vendor_0484_Product_5738.kl .....
Code:# cat /system/usr/keylayout/Vendor_046d_Product_c534.kl | grep 28 key 228 POUND key 28 DPAD_CENTER
Originally posted by zyxmon View PostOne new question - I have logitech keyboard+mouse connected to usb
Originally posted by diniket View PostI have problem for Tim vision and infinity app in Italy... The error is drm... Can I resolve this problem?
This includes TV versions of:
Netflix
Amazon Prime
And more
Sideload non ATV versions if possible
tillaz87 could you tell me the most compatible firmware for this box? Zoomtak upro 3/32 ddr4 7.1.2 unit has power button and clock.
dont trip. i got it.Last edited by Twisted714; 02 April 2018, 03:04.
Originally posted by iliasv82 View PostHello to everyone!!
I have a problem and I wonder if there is someone that can help me.
I've created the micro SD with the OS as the instructions said at the first post and I inserted it to my TV Box but it never went into recovery, instead it booted normally into my current OS.
The following steps from the instructions never happened to me when I insert the micro SD card in my Amlogic device and power it on:
1. You will be able to enter into recovery and the firmware will be flashed automatically.
2. When the TV BOX reboots
3. Remove the micro SD Card, this step is very important, wait 4-5 minutes and the update will completed.
I don't know what I did wrong.
Is there a specific way to boot my device from microSD?
Thank you!!
Originally posted by tillaz87 View Post
You used the keytest.apk to get the scancodes for remote? please attach the .kl you made
And what about powering off usb on suspend? Will it be enabled in the kernel/firmware? I'll adjust my script for it- but it is a temporary solution.
Hello to everyone!!
Thank you!!
I suffered from the same peril
hi !
to update from a SD card, you have to insert the SD card, put a paper clip in the reset hole on the bottom of the box, to push a bit till you feel a "click", to hold it pushed and then plug the power plug on without releasing the pressure on the paper clip. you can ask your wife/gf/mom/father/milkman/callgirl/anyone handy around to help you for that step.
when the message " installing update" appears, you can release the paper clip and let the update install.
warning : all your datas will be lost, so if you want to keep something, save it before
There are currently 1710 users online. 0 members and 1710 guests.
