[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by kole View PostHello
for some time, I have a loss of hdmi signal with the box, am obliged to remove the hdmi cable or unplug the power ...
a solution ?
Originally posted by Pinki View Post
Amazing, with UGOOS AM3 2.0.6 automatic framerate switch/automatic resolution switch is working properly with Kodi on my Beelink GT1 2GB.
Tillaz87 can you add this to your android tv rom? Playback options from 10.5 are buggy and doesn't work
How it works: when i play 4K HDR movie 23.976fps my tv switch to 3840x2140 23.976, whenn i start fullhd movie its change to 1920x1080 23.976 (depends of movie fps)
With it turned on its missing frames and in slow motion
With it off its perfect.
What tv do you have?
Edit:
Also looks like I removed stuff for it to work on here when converting framework to AOSP
Originally posted by tillaz87 View Post
I just flashed this and used Ethernet so could test the auto frame rate settings and it seriously brakes media playback on kodi for me when it's enabled but fine when off?
Edit:
Also looks like I removed stuff for it to work on here when converting framework to AOSPYou may only view thumbnails in this gallery. This gallery has 3 photos.3 Photos
You seem to be having multiple issues that I'm not seeing. Are you restoring data after install or something? or changing color settings?
There are currently 3665 users online. 0 members and 3665 guests.
