[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Just to report that I tested Beta 10 on a Sunveil T95Z Plus 2Gb/16gb which uses the AP6255 Wifi Chip.
Installed using SD Card; first installed the stock GT1 7.1.2 but not sure if thats necessary anymore (the stock does not work with remote)
Beta 10 Works perfectly, including remote.
Physical/digital clock on the device does not work, but I also don't care.
Netflix, Chrome, game emulators, all installed via sideload work perfectly.
Magisk installed via Recovery works perfectly.
Kodi (Android TV) works perfect.
Chromecasting does not work as expected, nor does Netflix (Android TV) due to lack of DRM support.
Box seems stable if a bit hot.
THANKS tillaz87 for amazing work, gave new life to my box.
Originally posted by craser View PostIs it possible to test it on the box H96pro + 3gb ddr4 32gb s912 ?? thank you
Originally posted by SocksKodi View PostTo change remote.conf file you need root or to disable read-only. What method do you recommend?
Originally posted by manvel View Post
I have installed v10 on my GT1 Ultimate G912/9377. Everything is working well, but as usual with Vorke/Tanix firmware on my device Bluetooth audio is broken and start to work only after replacements (with 644 permissions) of 2 files in system/lib and 1 file in system/lib/hw with this files [ATTACH]n706089[/ATTACH] .
Originally posted by ojerez View PostThe v10 is no longer installed from the terminal, right? I suppose it erases everything from v9?
Originally posted by ssss2 View PostJust to report that I tested Beta 10 on a Sunveil T95Z Plus 2Gb/16gb which uses the AP6255 Wifi Chip.
Thanks for reporting back, this is good to hear
Yeah I was expecting this, it happened back on modaco years ago, looks like Dropbox is still crap.. Will look into mega now.
Originally posted by SocksKodi View PostDo you know why even if I change remote.conf and can use the power button, if the box is completely powered off it doesn't turn on, only with the original remote.
Originally posted by Clayman_32 View PostNow testing, first thing I noticed is showing 2GB of Ram despite I have 3GB model.
Originally posted by tillaz87 View Post
Not sure, it works with mine (H1 with code learned) does everything work with the custom remote when its on?
If you learn the code it will work like the original one but mine sends a different code and I think maybe the turn on code is hardcoded dunno where. What is this suposed to change?
tillaz87, I am delighted. It's a stunning Android TV! My box YOKA KB2 PRO with remote T3 is working fine. That's what I wanted from TV Box. Just a little problem Wi-Fi, BT hardware. And some buttons on my remote I'm going to correct. Power on, Sleep & Awake working perfactly with T3 and stock remote. I'm very glad. Thank you so much,tillaz87.
if that zip don't work and its the same on stock z6 it would be part of the bootloader
One non related question. What version should I pick of SPMC
There are currently 1852 users online. 2 members and 1850 guests.
