[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
tillaz87 I checked new ROM and 3D games issue still exist. This is probably Beelink SN AX12 HW/SW issue and from what I see it looks like not enough memory for GPU. If anything works it is only when I decrease resolution using GLTools or screen refresh rate to 24 HZ, but then it is hard to play. On one of the forum someone wrote:
In any case I noticed that Beelink moved all the GPU memory carveouts on the CMA. This, with 3 GB of ram (and even with 2 GB), it's quite useless and, if it's not well configured, could cause the gpu issues we are experiencing. I suggest to Beelink (or to someone more able than me with custom roms) to disable the CMA for the GPU. I'm not sure it will resolve the problem but it would be a good starting point.
Is there any way to check that? I can make some tests and get logs, but I need to know what and how to do. Please let know what you think about that?
Originally posted by lapillo View Posttillaz87 I checked new ROM and 3D games issue still exist. This is probably Beelink SN AX12 HW/SW issue and from what I see it looks like not enough memory for GPU. If anything works it is only when I decrease resolution using GLTools or screen refresh rate to 24 HZ, but then it is hard to play. On one of the forum someone wrote:
The 706D variant also has RAM differences that cause it to default to 2G RAM. Does stock AX12 firmware also have this issue?
hard for me to debug as I don't have.
Originally posted by tillaz87 View Post
Beelink are a joke.. so many different hardware configs for this box, its a lucky dip buying one.
With the stock is the same (3d not working), beelink does not reply and actually for last couple of months I did not saw any thread saying it is fixed. Last month when 707 was released beelink replies that will check and this is all about that. Only hope is that someone who has huge knowledge can check what is wrong with this version. If there is any app that can ba run co get deep hw info or debug GPU in details, I'm willing to run it.
I suspect AX12 has bad hardware and possibly why 706D came soon after as beelink wont even acknowledge the issue with AX12
probably because they know its hardware. which then legally should call back all AX12 with RMA like Nvidia had to do.. (and did for me)
But this is Chinese so that's never going to happen.. You have more chance of "Jensen Huang" knocking on your door with a unreleased shield TV.
I have some tests later on you can do to try gather info on whats broke
then open a game, double press home button straight after and go into terminal and enter "cat /d/mali0/gpu_memory"
show me the result
from terminal app enter "free" and show me the total
show me the result
1 - after reboot
2 - buggy race launched with full details. After loading game is stucked
3 - changed output settings to 1080p-24hz. Game is working but only 15 fps
There are currently 3185 users online. 1 members and 3184 guests.
