[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
    Thx for your work, i try your v10 on GT1 Ultimate !
    Do you know why the mouse can't select caracteres on the virtual keyboard ?
      Hi,I would like to thank you for all your time and hard work. I have a Gt1 Ultimate AX12 and I have had very good luck running all versions of this Rom. I have experienced the reported 3d/ Antutu issues with this as well as the stock 707NO and the other versions I tried of this ROM. However what I have found testing with this ROM running 3Dmark or GFXBench is that the tests that are failing, are only failing on the OpenGL 2.x tests, all the 3.x ones run repeatedly with no crashes. On the GFXBench T-rex OpenGL 2.0 one it reports in the test results out_of_memory and it locks up quickly. With all the OpenGl 3.0 tests running fine prior. I thought that perhaps others with the AX12 S/N might want to try these tests and see if their experiences are the same. Again thanks for all the great work.
        Originally posted by Mathieu73460 View Post
        Because the leanback keyboard does not support it. Install an other keyboard.
          Originally posted by tillaz87 View Post
          Tested 10b during Saturday:
          Got two time freezing of picture on the screen and complete stuck of box (GT1 ultimate G912) during watching of stream movie from internet server using MX player. Then was able to restore work only by reconnection of power cord. Then change to another ATV custom rom on the bases of Vorke Z6 and got similar thing: this time just connected some IPTV channel and after one hour of working came to the same result. I think the problem in adaptation of Z6 firmware to GT1 ultimate hardware. With 707N0 firmware (ATV or usual android) I can use box days without any freezing. But Z6 variant is more fast and smooth ,of course.
            IMO MXPlayer is not perfect. Not sure but either Nugat or Oero has broken MXplayer playback smoothness.
            One reason why I am slow to adopt Nugat and Oero for compatibility and unknown or unwanted playback issues. Once there is a good build that is stable, dumping MXPlayer will not be an issue. I rather use Tubemate for streaming for most everything outside of pay services.
              Choice excellent
                Originally posted by macavita View Post
                i flashed V10 and now i cant login to "DEEZER"
                Pls HELP
                  Hello
                  on netflix, I just installed the Netflix HD Version 5.0.5 and
                  Netflix 5.12.2 build 25768 (arm) very functional
                    Edit: Fixed
                      Guess i will go back to v9...
                        Originally posted by kole View Post
                        Hello
                        Where is this versión of Netflix HD? Can you pu the download link?
                          I will put you the files via Mega after my work in the evening
                            can you watch Netflix in HD?
                            Thank you
                              Is it possible to put a password at start ?
