[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by aitors30 View Post
Use the Netflix apk android TV version from uptodown. It's works perfect.
You mean this one: http://netflix-inc-netflix.en.uptodown.com/android ?
Originally posted by benn0s1991 View Post
In combination with this ROM?
Sorry.. From apk mirror... Netflix androidtv apk... Last version.
I allready tried those versions but none of them are working.. getting the same ui-800-3 error
reflashed the ROM, logoff all devices from netflix, reset application, nothing solves the problem
The APK from APK mirror is the same version as the one i download from the playstore.. what is the difference?
Originally posted by aitors30 View PostBeelink gt1 ultimate... I tried to update to V3 this night. I suppose it's works again. But I ask if we can update to last version without made a factory reset......
Enviado desde mi ONEPLUS A3003 mediante Tapatalk
For now its not possible without a Factory reset as far as i know..
Originally posted by Djuganight View PostI have tried to update my GT1 (A912) via SDCard gave update error and my box now don't do nothing more.
Only turn on the blue led light but appears to be dead!
What can I do?
Originally posted by benn0s1991 View PostAnyone got the Netflix TV app working using this ROM?
I installed it from the playstore but getting error: netflix ui-800-3
Trying to Install Magisk 13.3.zip to hide root to see if that solves the Netflix problem but getting: Boot image not found when trying to flash using TWRP
Any idea's?
Flashing that removes beelinks detectable root and replaces it with the offical systemless root method for superSU, this is undetectable. My5 only works after doing this so all other apps should be the same.
But bare in mind netflix are cracking down heavy on blocking their app from devices that are rooted and don't have widevine level 1
Originally posted by aitors30 View PostExcellent work tillaz87. I installed the ROM yesterday without any problems. But I see that you released the V3 today. If there any form to update without make a factory reset and loss my config?? Thanks for all!!!!!
I will update later on today to support thisLast edited by tillaz87; 27 July 2017, 14:53.
[QUOTE=tillaz87;n659002]
I though i allready flashed the Chainfire root file but i will check it again!
Is it possible to flash Magisk? With magisk installed we have the option to hide root and have a succesful Safetynet pass, maybe that will solve the Netflix problem?
Phone version of Netflix is working fine..
Awesome work btw! ROM is running super smooth!
The problems with the tv version is common though as another developer on here was talking with me a month back about not been able to get it working from the market. I guess that's because they upped security in the latest update.. after reading this article I switched to using an alternative https://www.google.co.uk/amp/s/www.t...ndroid-devices
[QUOTE=tillaz87;n659006]Originally posted by benn0s1991 View Post
I've never used magisk before and stopped my netfilx subscription a while ago when they started getting agressive with blocking devices with root and without widevine level 1 (something these boxes won't ever have) so I'm really unsure about it
The problems with the tv version is common though as another developer on here was talking with me a month back about not been able to get it working from the market. I guess that's because they upped security in the latest update.. after reading this article https://www.google.co.uk/amp/s/www.t...ndroid-devices I switched to using an alternative
Is it possible to unroot this ROM after i flashed it?
Jst want to try out, maybe unroot wil solve my issue..
There are currently 1385 users online. 1 members and 1384 guests.
