I have Samsungs top end 4k tv but still prefer RGB as it allows deeper blacks using an option that is only available on RGB so know it works
[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by thgiakit View PostPS I download the 1.zip but can't unzip it. It says that it is in a non readable format. Can you please re-upload your script?
use notepad++ to open it by right clicking on it and selecting open with notepad++
It also should not be called 1.zip it should just be 1 with no extension
Edit:
What are you wanting to change in the script ?
Originally posted by tillaz87 View Post
that's a problem on your end, the script is fine.
Edit:
PS: I do not want to change anything concening the script
[QUOTE=nerdoo;n662955]First off congrats for the sticky ... well deserved
Just to help others wondering about simple things:
As this rom is Android TV so ONLY Remote Control supporting apps/games are available for install in Play (mentioned above), and they are not that many BTW.
Life is definitely easier with an Air Mouse, which works even in TWRP recovery..... mine is MeLE F10 Deluxe
Thanks nerdoo, but were you able to find a way to use the Melee f10?
Originally posted by nerdoo View PostSure.... Just plugged in the wireless USB adapter and it worked out of the box right away........ No extra effort on my part.
Originally posted by tntsj408 View PostIm having an issue with an Xbox controller. When I press left of the D-Pad, the power menu comes up (Suspend, Shutdown, and Reboot). Is there anything I can do to unbind/stop that from happening?
Anyways I ordered a bluetooth controller.
Originally posted by minonano View Postall work on it but the andoid keyboard and mainly the Enter button does not. so i have to use the f10 keyboard insted, Does your Enter key on android keyboard work?
........ BTW long press on power button gives option to shut down while short press sleep.
Hello everyone,
I currently have a GT1 box (standard) with the original firmware (Androïd Marshmallow version 6).
It does not propose to go into version 7 via the OTA.
I would like to install the Androïd TV version 7.1.2
Can you help me ? I would not damage the box.
I would like to have just the steps to perform. On the site it talks about the update 2 / the 3 files to copy and the firmware.
Can I install the flash rom directly?
Thank you in advance,
S/N beginning with S912 or G912 = A9377 WiFi chipset ------ S/N beginning with A912 = AP6255 WiFi chipset
AP6255 STOCK 7.1.2 <----> A9377 STOCK 7.1.2
2. Then download the 3 files below it:
V3
Script
Apk
3. Place them on a usb or sdcard insert it into your GT1.. copy them over to the base directory: /sdcard/
4. Install the terminal app and run the terminal app
5. Run the following commands in the app.
su
sh /sdcard/1
Thats all to it
There are currently 3936 users online. 1 members and 3935 guests.
