[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by Kayoo View PostDoes someone try Dolphin (wii emulator) with this firmware ?
Give it a try and let us know, https://dl.dolphin-emu.org/builds/do...r-5.0-5620.apk
Roms here just make sure you own the games you download to keep it legal and all that :/ lol
Originally posted by CanadianDreamer View PostThanks to tillaz87 for this great ROM. Now my issue.
Just last night the GT1 Ultimate went into a boot loop just after the Google Splash screen? Day before it did the same until I removed the USB drive I had plugged in? Any ideas?
Thanks?
CD
Could also be that it's not getting enough power to run both devices if the usb drive does not provided it's own power. This can cause what you describe.
I see this when I try to power with usb only and using 4k output
edit:
if you have a male to male usb and a spare port on your box try plugging it into your box and tv to give extra power to the plug
Originally posted by tillaz87 View Post
Do you have some type of bootable media on your usb drive? An old ota or something?
edit:
My last evening experience did not have the USB drive plugged and the box still would not boot up..... I will try again tonight.
CD
CD
what root apps have you installed?
would need to know more about what you have installed, and had done before this happened to understand what caused it. random bootloops are normally self caused and the result of a system file change
if not a power issue
did you try to update the superSU binary without flashing the zip on first post?
I have not installed a root app except what is packaged with your ROM.
Last evening the box booted up fine with no USB device plugged in...... Go Figure!!
Thanks,
CD
Can't really help then as no one else has reported this or experianced this myself and I have had mine running 7.1.2 for about 2 month now with USB plugged in and all sorts.
I would recommends flashing stock and removing root as without root nothing can alter the system to cause a boot loop
Maybe try flashing the zip in recovery fist see if that helps then if it does remove root
There are currently 3705 users online. 0 members and 3705 guests.
