[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
    Originally posted by tillaz87 View Post
    interesting, its working fine with mine. you might have a different variant
    in terminal do
    Code:
    su
    Code:
    cat /proc/bus/input/devices
    look for "xbox 360 wireless receiver (Xbox)" tell me the values above that for Vendor= and Product=
    also install this apk open it and press each dpad button and tell me the scanCode= value foe each direction.
    with all the above information i would be to make a keylayout for your variant
    I'm using an official x360 receiver and controller.
    Here is the information requested.
    Actual Press | Keycode_DPAD_ | Scancode
    Left | Right | 705
    Right | Up | 706
    Up | Down | 707
    Down | Unknown | 708
    Vendor = 045e
    Product = 0719
    Using that keycode apk i confirmed that the other presses are correct.
      Left | Right | 705
      Right | Up | 706
      Up | Down | 707
      Vendor = 045e
      Product = 0719
      Yeah, the rom has no keylayout for this variant. so it uses generic.kl that's why its a bit messed up.
      i will add support for it in next update
        Left | Right | 705
        Right | Up | 706
        Up | Down | 707
        Vendor = 045e
        Product = 0719
        extract this Vendor_045e_Product_0719.zip (cant upload .kl) add "Vendor_045e_Product_0719.kl" to system/usr/keylayout/
        set permissions for it and reboot, unplug and reconnect receiver
        Edit:
        tntsj408 Updated the link try the above
          Actually I already included this keylayout just checked the rom .zip, think i know whats wrong
          Edit:
          Fixed should work now. see post above
            How do I copy it to the system folder? I tried using the terminal with su using command:
            cp Vendor_045e_Product_0719.kl /system/usr/keylayout
            And it says: Read-only file system
            How do I get around that to copy it in there?
            Nevermind... I found an app in the store with root access that was able to do it.
            Controller works perfect with that layout.
              Hi Tillaz87,
              I've updated to V4 and the shutdown prompt is still present
              And I can't find the access point setting in your firmware
              Help please.
                Originally posted by xom2000 View Post
                Hi Tillaz87,
                Help please.
                What stock firmware are you using? shutdown prompt should not be showing with left dpad
                if you mean wifi AP its not supported in android TV as its part of phone/tablet settings.apk
                  7.1.2
                    7.1.2
                    should be working if your using stock 7.1.2 from beelink, double check your using the latest script and not the old one. or just flash the zip in recovery
                      Guys anyone managed to successfully pair/connect a bluetooth gamepad with this rom?
                      I just got one, RK-Game 4th Gen game controller, and my box doesn't even see/discover it!
                      It did however see and pair a bluetooth headset!
                      I am on latest V4, flashed via recovery.
                        I've paired Xbox one s Bluetooth controller and ipaga controller
                        Bluetooth is untouched from stock so should just be the same
                          I think shutdown prompt appears after the TV-box wakes up from the sleep mode with the standard remote
                          P.S. Sorry for my poor English
                            As got this one recently I didn't try it on stock, it did pair with my phone LG G4 after few attempts.
                            Installed Bluetooth pair app but still no luck.
                            As I mentioned my GT1 box did pair with a couple of things but for some reason can't discover this controller
                            Any tips,things to try?
                              I have noticed some things are not recognised with the tv pairing. for example my light bulbs are not recognised unless using the "more settings" bluetooth option which is part of settings.apk but that currently wont work with atv. I have been meaning to port over the version from lineagOS that has action bar changes to work with atv but not had time recently
                                Thanks mate ... good to know there is something to try ..... I had also a couple of things that weren't recognisable either.
                                Look forward to changes when you eventually get the time
