I've installed (sideloaded) apkpure as a way to install smartphone apks but apkpure switches to portrait mode. I installed your build of Android TV just a few hours ago I should have the latest version, shouldn't I?
[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
then, settings / droid settings / orientation
Originally posted by tillaz87 View Post
install this [ATTACH]n676167[/ATTACH]
I've installed Orientation.apk but this did not fix the problem. Anyway I fixed it by myself after realizing it was a permission problem. The program needed permissions and was asking me if I wanted to grant them to it. I had to say yes before it switched in landscape mode. So I set permissions to true in Settings ->; Applications before launching apkpure again. Now it works in landscape mode !
It's still advised to do the above as it's missing from the latest update and forces all apk to use landscape which otherwise some would be stuck in portrait like most of the UK tv apps
Orientation option in droid settings will force close without it. need to select landscape from that option for it to work
Magendanz do you have a link to this firmware with the fix and the release before the change? I want to have a look at what they done
There are links to the original OEM firmware (V0321 & V0619) on the OP of my thread here: http://freaktab.com/forum/tv-player-...android-tv-7-1
Originally posted by tillaz87 View PostCan't really help then as no one else has reported this or experianced this myself and I have had mine running 7.1.2 for about 2 month now with USB plugged in and all sorts.
I would recommends flashing stock and removing root as without root nothing can alter the system to cause a boot loop
Maybe try flashing the zip in recovery fist see if that helps then if it does remove root
CD
Originally posted by CanadianDreamer View Post
Ok... I have reflashed the stock and your ROM.... How do I "remove root"? I don't see an app to do this. ...
CD
Here is settings.apk you can try for pairing that gamepad. its not fully ported yet the bluetooth part is only working.
flash in recovery, open from app draw, back out of it and open again (makes remote work) open bluetooth and tell me if you can pair.
I can confirm pairing with light bulbs and Samsung TV which is not possible threw TV settings.
Edit:
Actually, this might not work unless your running latest stock 7.1.2 if not just delete it from system/priv-app
I did try this Settings.apk and it worked fine showing and connecting a bunch of bluetooth peripherals that the rom's own BT settings usually don't even discover!
The joystick (RK-Game 4th Gen) I tried this for was discovered but unfortunately it gets stuck on pairing without managing to pair properly despite numerous attempts.
Of course not everything works in these settings leading to FC, but BT works fine
My box is G912/A9377 on V5 of rom
Thanks tillaz87! It works! good job! I now can BT my PS3 controllers and the keys mapping are nicely done. no keys overlap like the original rom.
Btw, I cant seems to mirror for my phone to my GT1 ulti.. the miracast app is gone. and also can seems to BT files over. Please advise.. Thanks!
Originally posted by shiva-x View PostIs Gamesir g4s compatible with this ROM or should I buy something else ?
I can also easily make a keymap for any controller with the owners help and ad to rom.
at £47 I would rather pick up the xbox one s controller for £42 which works great, just an idea.
I cant see why any Bluetooth controller wouldn't work unless its been put into the wrong pairing mode, as to pair with iphone it was a different combo on some of the older ones.
https://www.amazon.co.uk/Official-Xb...2Bgamepad&th=1
I hope I'm not full off topic, if yes I'll delete it on request.
There are currently 2421 users online. 1 members and 2420 guests.
