You'd better put the supersu zip file on the sd card before flashing.
[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
If I am connected using the LAN chip BT is very intermittent, connect, disconnect steady.... If I connect with WIFI, BT works fine. Any suggestions???
Thanks,
CD
Could be poorly designed / placed hardware causing interference. these boxes normally have poor wireless connectivity to start with so hard to say
But I've not changed anything in that area so if its not hardware it would be beelinks stock builds
Originally posted by tillaz87 View Post
No idea my PC does a similar thing with BT.
Thanks for the help on the boot to recovery...
CD
I'm using your Rom since two days, very good work !
But I've a problem with plex and DTS sound ! Plex can play sound for all movies except DTS 5.1 !
Before your Rom I was using superceleron SCV2-ATV Android 6 Rom and DTS sound works fine (after disabling passthrough) !
Has someone a solution ?
Originally posted by sharkzeo View Posthow lo see my wifi chip my gt1 ultimate S/n AX12GSKH407.. DO I NEED TO OPEN BOX???
$su
(authorize supersu root request for the terminal emulator)
#ifconfig
I was too lazy to test on my GT1 but it works OK on my Nexus 5. There are apps on the playstore that do the exact same thing as I described (very briefly) above, but I'm not sure they work on Android TV.
about BT, i trying some BT connections, but fail... i can't connect my samsung galaxy s7 edge to gt1 (with tillaz rom)... gt1 not have advanced settings for bt (or i can't find it yet)... using bt icon from settings @ gt1 only gives "waiting for accessories...." while samsung give me message about code that i need to confirm @ gt1 and soon lost/break attempt to pair/connect.. from other side gt1 not ask me to confirm any code, just siting and waiting for accessories....
it's normal or i doing something wrong... maybe some app for bt settings? whatever?
what is best, confirmed combo apps for streaming/cast multimedia over lan/wifi (sources are pc and phone/tablet, destination is gt1/tvbox? (confirmed to work with tillaz rom)
about games, tillaz gave me some tips... but i still have problems... i have original remote and logitech k400 keyboard, but not gamepads.. trying some virtual gamepads (work only through wifi receiver/client app, not as BT.. even not all keys, only A B buttons, not directions).... it's about games with gamepad support... but what about true touchscreen games, how to play touch games without touch screen? it's possible?
There are currently 3019 users online. 0 members and 3019 guests.
