Will sort that in next update
[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tillaz87 View Post
Ah yeah that's no longer needed now, I must of forgot to remove code from droid settings for it.
Also, the portrait mode is required as well since I need to choose certain settings on the app during initial setup, buttons for which overlap with other buttons in the landscape mode. For example, the SKIP button overlaps with the Facebook Login button in landscape mode.
I used ‘portrait mode’ orientation setting to launch these apps for the first launch and later switched to landscape mode. I can’t do that switch now and the app runs in portrait mode forever.
So, please bring back this setting. It will be a great help.
Cheers,
Originally posted by juancabu93 View PostDoes miracast work with this ATV ROM? Thx!!
To test miracast you would need to sideload an app like "Allcast" as the native setting is not part of TVsettings
And the standard settings.apk which has the native option for miracast is broke on all ATV at the moment because of the changes to action bar that it enforces.
Ideally amlogic should merge the changes from lineageOS for action bar in their SDK for settings to be supported properly on ATV.
Or I merge them them in AOSP and then port to this but the porting is so time consuming and tedious I can't see me doing it anytime soon.
Plus everything it offers can be used via external apps from market.
Give Allcast a try and let me know.
I have a gt1 32gb with ap6255 wifichip. I first installed latetst firmware from beelink (704). It boots normally . After first start of the beelink firmware I started your script with V5. The script starts running (step 1 to 6) and my tvbox reboots.. I do get the beelink screen and after that the please wait screen. I've waited more than half an hour but nothing changes (still please wait). I've started the whole procedure again but with the same result. Any Idea what I'm doing wrong.? BTW I do notice that one of the last Actions of your script gives An error Just before the reboot.
Originally posted by ronvanv View PostI have a gt1 32gb with ap6255 wifichip. I first installed latetst firmware from beelink (704). It boots normally . After first start of the beelink firmware I started your script with V5. The script starts running (step 1 to 6) and my tvbox reboots.. I do get the beelink screen and after that the please wait screen. I've waited more than half an hour but nothing changes (still please wait). I've started the whole procedure again but with the same result. Any Idea what I'm doing wrong.? BTW I do notice that one of the last Actions of your script gives An error Just before the reboot.
if you see beelink screen it sounds like it didn't install the zip. are you sure its on internal storage while running script?Last edited by tillaz87; 09 September 2017, 15:52.
You should see a google screen on reboot after running the script, if you see beelink screen it sounds like it didn't install the zip. are you sure its on internal storage while running script?
t
Thank you very much to the developer.
this rom better than stock software.
very good, Beelink transformed to Mibox3.
Why cpu frekans 2ghz to 1.5ghz?
bug: Setting>Droid Setting>Orientation> error
how can i access full seeting page?
how can i install second mobil play store for another app?Last edited by ilkertr; 11 September 2017, 16:26.
Similar thing for play store as this is ATV it uses googles tv variant, so you would need to sideload apps that are not it.
Originally posted by Kingmarth View PostI can't get my h96 pro remote to work with the box
I did upload remote.config to etc folder.
There are currently 2741 users online. 1 members and 2740 guests.
