[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tillaz87 View PostIdealy I would like to remove beelinks root while installing, in fact I will do this in the next update so we know its really gone and nothing is been left behind. it's safer that way anyway to be fair
Originally posted by aitors30 View PostExcellent work tillaz87. I installed the ROM yesterday without any problems. But I see that you released the V3 today. If there any form to update without make a factory reset and loss my config?? Thanks for all!!!!!
use this script to flash twrp, just put the latest rom .zip on internal sdcard and run the below
Code:[B]su[/B]
Code:[B]sh /sdcard/2[/B]
Originally posted by benn0s1991 View Post
I allready tried this by editing my build.prop to nvidia shield, couldnt reboot after that
In this rom i'm spoofing mi box so we get 4k youtube without apps downloading wrong data as we have same GPU family
flashing build.prop now will update my result soon.
probably changed to much, I used to spoof the shield tv for iplayer to work on here (took from my shield) until i just modified the app to point at a prop that has no use.
btw. unroot using SuperSU is not working with this ROM
really curious right now, good luck!
Edit:
Your right it cant be removed, I'm uploading new version now which removes beelinks root, people can then choose to install root via twrp if they want it
I dont think any files are stored on the system with systemless root but it should still remove superSU app will have a quick look
Edit:
I hope to find a way to unroot/hide root to see if that will fix the problem...
What do you mean by new version, a unrooted version of the ROM?
Just tried your Build.prop, device boots properly but netflix still has the same problem.
I was sure this root method was removed with factory reset, will give that a quick check..
Yeah, the next version removes the stock roms root then boots to recovery so the user can decided to root of not, You would need to flash your stock firmware again though first so the boot.img is restored.
So first flash stock 7.1.2 rom, after that running the new update using terminal?
wait for v4 though if you do re-flash stock
Factory reset removes this root method, no need to reflash. although you could try that to be sure the boot.img stuff is restored
I guess i wont get it working on this box
There are currently 1906 users online. 1 members and 1905 guests.
