[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
    Originally posted by benn0s1991 View Post
    Isn't the stock rom rooted by default?
    yeah but the superSU zip removes it from what i can see after factory reset
      I just did the factory reset, still the same Netflix problem, checked root with the Root checker app, says no root access..
      I guess i wont get it working on this box
      Ive not seen many people have much luck with the tv version without widevine L1, but someone on here did say they had it working so not sure. its a long shot but maybe try changing your langue to English US or English GB as that is the only possible difference between you and the person that has it working a few pages back
      there is an alternative thats actually better and free.. <--that's also debatable :/ so pm me if you want and I can point you in the right direction
        I tried, changing the lanquage doesn't work either, you mean terrarium tv?
            Had a phone call for about an hour with Netflix Technical support, they couldn't find a solution either..
              try the builds pre march 2017 as that's when they upped security with root and stuff
              try december 2016 version
                Try a pre march 2017 version as that's when they started blocking root / unlocked bootloaders and stuff, give the December 2016 apk a try
                http://www.apkmirror.com/apk/netflix...-apk-download/
                and this one right back to 2015
                and this is said to be modded to work
                  Thanks..... Work perfect!!!!
                  Enviado desde mi ONEPLUS A3003 mediante Tapatalk
                    https://forum.xda-developers.com/sho...90&postcount=6
                    I already tried a lot of versions including older ones and modded versions from XDA, i will try the versions you sent me!
                      You mean the Netflix versions he posted?
                        Sorry... It's for new script without factory reset...I made Netflix work only download last apk from apkmirror and install it.
                          Could you try one of the versions he posted?
                            follow the steps but no luck
                            i got error : no such file in the deirectory
                            any one who can help... regards
                            p.s stuck on stock firmware 7.1.2
                              Hi....ok. I probe the versions and I confirm that the unique that work are 5.3.0 download from apkmirror. The android TV version get error 803 connect. I supposed is for the DRM and not verified tvbox!!!!!!
                                You need to make sure the files you downloaded are in the root of internal storage (not in a folder) which is /sdcard
