[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
    Originally posted by tntsj408 View Post
    1. You first need to burn the stock 7.1.2 image. Pick which is your system..
    S/N beginning with S912 or G912 = A9377 WiFi chipset ------ S/N beginning with A912 = AP6255 WiFi chipset
    AP6255 STOCK 7.1.2 <----> A9377 STOCK 7.1.2
    2. Then download the 3 files below it:
    V3
    Script
    Apk
    3. Place them on a usb or sdcard insert it into your GT1.. copy them over to the base directory: /sdcard/
    4. Install the terminal app and run the terminal app
    5. Run the following commands in the app.
    su
    sh /sdcard/1
    Thats all to it
    Thank you very much for your quick response.
    I flashed in version 7.1.2 this is ok.
    I copied the 3 files on the SD card but there is an error message with the sh /sdcard/1 command to see the photos.
    If you have an idea?
      https://i.goopics.net/a4dLk.jpg
      files need to be on internal storage, which is named sdcard
        I can not find the SDCARD location in the FileBrowser.
        Do you know or is the SDCARD location in the FileBrowser utility?
          Updated
          Important:
          To update without wipe flash the .zip in recovery Download
          Flash this in recovery for proper root (Stock Method Is Not safe) Download
          Update 3:
          • Fixed wireless Xbox 360 problem (left D-pad opening power menu)
          • build.prop corrections
          • Cleaned up some junk
          • updated apps
          • Bluetooth stuff for 9277
          I'm no longer supporting 7.1.1 as it has many more bugs than 7.1.2 and if beelink update again it would be 7.1.2
            its just the internal storage, so its the first option in stock file manager
            sideload es file explorer its a bit easier to see
              I can not download the file A9377 STORY 7.1.2. I get an error from beelink-my.sharepoint.com. Is it possible to download this file from another resource?
                They have messed access up on their one drive we will have to wait for them to correct it.
                I'm waiting to download the new version of 7.1.2 they uploaded today so I can compare all differences
                  Hooray! Everything worked! I am waiting for you to download a new version.
                    i've seen intereting video
                    he used gt1 stock upgrade app for flashing zip.
                    is it possible to this?
                      Hi tillaz,
                      thanks for the hard work.
                      I want to update to the new version without wipe, how I enter in recovery mode?
                        Originally posted by Jabaneco View Post
                        Hi tillaz,
                        if your 6255 wifi i would update to latest 7.1.2 stock build first then use v5 which im releasing tomorrow. however that would require a wipe.
                        if not just download a reboot app from market and reboot to recovery
                          Here is the latest 7.1.2 for 6255 wifi that released few days ago https://beelink-my.sharepoint.com/pe...HjHhjCU7I4Qob8
                          Beelink look to have removed it from freaktab for some reason, its working fine though v5 is based of it
                            I've added Bluetooth pairing shortcut to the launcher
                            had also in the passed added a power option for reboot, rebooting to recovery and powering off as i use the amazon Bluetooth remote.
                            but when i realised I couldn't power back on with bt remote scrapped it.. Any thoughts on this are welcome as not sure about it
                              Hi Tillaz87,
                              I updated to V4 and the shutdown prompt has gone away but another issue ive found is the xbox 360 wireless D-pad mappings are off now. They were fine before but the pop up would come up.
                              Now here are the presses on the d-pad (V4):
                              Press => Effect
                              Left => Right
                              Up => Down
                              Right => Up
                              Down => Nothing
                              Would be awesome if you can fix that mapping for V5.
                                Hi Tillaz87,
                                Press =&gt; Effect
                                Left =&gt; Right
                                Up =&gt; Down
                                Right =&gt; Up
                                Down =&gt; Nothing
                                interesting, its working fine with mine. you might have a different variant
                                in terminal do
                                Code:
                                su
                                Code:
                                cat /proc/bus/input/devices
                                look for "xbox 360 wireless receiver (Xbox)" tell me the values above that for Vendor= and Product=
                                also install this apk open it and press each dpad button and tell me the scanCode= value foe each direction.
                                with all the above information i would be to make a keylayout for your variant
