[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
I read your comments there about replacing build prop with mibox and disabling the action bar and notification and one thing I dislike in your rom is the power icon on the bottom. Magendaz looks better. But I can't find where the kodi button and the rest is hardcoded in his build. Still thinking if I should give up on the IR. Its just annoying having to use 1 remote just for 1 button
Originally posted by SocksKodi View Postone thing I dislike in your rom is the power icon on the bottom. Magendaz looks better. But I can't find where the kodi button and the rest is hardcoded in his build. Still thinking if I should give up on the IR. Its just annoying having to use 1 remote just for 1 button
but to be fair we don't really need it since I added recovery to the in built power menu.
it would be better if someone could build an apk that just launches the in built power menu, my efforts all failed
Just tried it, same result. I had cleared cache/dalvik cache too post flashing.
Also, I somehow feel this has got something to do with the screen rotation functionality which has been removed in your versions. Do you have the files from 707NO that I can directly replace/add after your patch to regain this functionality?
I tried to use Amlogic Rom Customization tool to unpack 707NO for extracting screen-rotation related files, but it is giving me some weird JDK error.
Cheers,
There are currently 2694 users online. 1 members and 2693 guests.
