[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
All good with your V8 version, as always
However, I am facing a couple of issues since last few releases:
1. I can't use 'OK' button on my Air Mouse Remote (MX3-M https://www.banggood.com/MX3-M-Wirel...p-1025228.html) to select keyboard characters using 'Leanback Keyboard'. The OK button works otherwise (even to select 'Go' or 'Proceed' on the leanback keyboard) in all other apps.
2. Amazon Prime Video has stopped working. I can sign-in and even load previews but the app crashes while loading the actual videos. This doesn't happen with stock 707NO, or any of Beelink's original firmwares. Is there a way to fix this, using build.prop editing or something else? There is another app called 'VOOT' which works fine in stock 707NO, but crashes upon launch with your patch applied.
Cheers,Last edited by mrish; 11 December 2017, 08:47.
Originally posted by tillaz87 View Post
What app is it? never heard of apps been so desperate for ad-sense revenue.. ads=malware to me (90% of time) should be paid or free.
flash this to stop the blocking of shady ads lol [ATTACH]n692170[/ATTACH]
Originally posted by mrish View Post2. Amazon Prime Video has stopped working. I can sign-in and even load previews but the app crashes while loading the actual videos. This doesn't happen with stock 707NO, or any of Beelink's original firmwares. Is there a way to fix this, using build.prop editing or something else? There is another app called 'VOOT' which works fine in stock 707NO, but crashes upon launch with your patch applied.
Cheers,
But I had a look at the Android documentation about key layouts: https://source.android.com/devices/i...y-layout-files
According to this one, placing the custom key layouts under '/data/system/devices/keylayout/' may be a more graceful way instead of troubling the otherwise read-only '/system' partition. I tried this but it didn't work for some reason.
will look into it
This worked, thanks!
Will appreciate your help, thanks!
Anything added to the data partition is lost on factory reset so not ideal even if it did work.
Not to mention the Data partition is more locked down than system, without root and busybox you can't even view it in a file manager as this is where apps are pulled and pirated.
The idea is that manufactures of these input devices use scancodes that match the generic.kl as its universal across android devices
If you made a .kl for you remote please upload it so it can included. Same for everyone else.
Originally posted by henjuck View Postthk very good rom !!
are u tested
http://www.bee-link.com/forum.php?mo...e%3D1&mobile=2
this netflex???
Originally posted by kole View PostGood evening
In the display settings. I have the screen option in HDR or SDR ..
Which is more suitable for gt1 on a tv Samsung
Maybe I will change my mind when I get an oled as these are best for HDR
Edit:
just depends what you like if on /off
You don't have root, must of removed it? reflsh stock then this
There are currently 2922 users online. 1 members and 2921 guests.
