[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tillaz87 View Post
updated the revert link
I am using the latest Prime Video app on the playstore. Can share it if you need..
Cheers,
Originally posted by mrish View Post
Thanks, just tried with look.zip. Prime Video still crashing upon launch.
Cheers,
if its crashing upon launch that's a webview problem, what did you flash this patch over?
Can you send me the apk you are using? as the above works for me, and without the above it only crashes when trying to play video
https://www.dropbox.com/s/u7opyw3izw...Video.apk?dl=1
- I had V8 running over 707NO + your V6 build.prop. Later I replaced the V6 buid.prop with the one from V8. Still no luck..
Cheers,
- My bad.. yes, Prime Video crashes while trying to play the video. Voot crashes upon launch only. Have shared links for both, please have a look :
- About the webview thing, on Prime Video I noticed that 'sometimes' the video starts playing while the crash banner pops up. Not sure if this will help you in finding the issue.
Cheers,
There are currently 2124 users online. 1 members and 2123 guests.
