[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Please somebody help me. I can not install original 707NO firmware, (usb burning tools 2.1.2 (I try different version)) do not see tv box.
1. I push reset btn and connect usb cable (try different usb on tv box)
2. I turn on (off) usb debugging
3. Program "Usb burning tool" running as administrator
4. I try this with (and without) power adaptor
I do not know where I make mistake
My box is GT1 ultimate 3/32 (AX12 with bad 3d), firmware "
Multi 6255 & 9377 Standard+Ultimate" v7 from Tilaz and I want flash v8
win10 64bit with last update
Originally posted by mykola7619 View PostPlease somebody help me. I can not install original 707NO firmware, (usb burning tools 2.1.2 (I try different version)) do not see tv box.
Originally posted by rmarksts View PostI'm with same problem, my beelink os like tours, i need help too, somebody?
Run usb burning tool
File -> Import de firmware
press start
connect the usb cable to the tv box usb port (lateral). Note: USB port in the PC side must be 2.0.
It is not necessary push reset button
It is not necessary plug the power adaptor.
Originally posted by kwatto View Post
without connect the tv box to the PC
press start
This may not be the right thread for this question but here goes;
I recently installed this Android TV rom on my GT1 Ultimate. The install was successful and I am able get wifi working by using WPS Button method.
Issue: I tried TeamViewer to remote manage but the the QuickSupport version does not see the device as compatible. Sideloading the Host version allows the remote view but renders the entire device buggy causing apps and launcher to crash soon after a successful connection.
Has anyone been able to get TeamViewer Host to work after ROM change to Android TV?
There are currently 1781 users online. 0 members and 1781 guests.
