The one included in older stock z6 firmware is 17.v4 and does not have above issue.
[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Hello tillaz87
I'm a newbie in the world of android, but after many process, I finally installed your ATV ROM witch is smarter than the original, great job !
However, I have two problem for now :
- Impossible to activate the WIFI, my gt1 ultimate is far from my internet box so I absolutely need the WIFI
- The MyCanal app (live TV) doesn't work properly, when I pick a channel, I have the sound but the screen freeze instantanly.
As a newbie, I don't really know witch gt1 ultimate I have, I only know this :
- CPU : Amlogic S912 Octa Core ARM Cortex-A53
- S/N beginning : B706DB
Is there an issue for that .
Thanks a lot
Thanks a lot- add zip to sdcard
- use power menu to reboot recovery
- Install ZIP from SD Card
- reboot
Originally posted by tillaz87 View Post
flash this in recovery tell me if WiFi fixed http://freaktab.com/forum/tv-player-...682#post710682- add zip to sdcard
- reboot
Thanks btw
Originally posted by CheckMate View PostHi again,
I will specify something : I can activate WIFI but it doesn't detect anything, despite the 2 internet box here.
Can you direct me to your stock rom for this variant where WiFi + BT works?
I will try adding support
There are currently 2957 users online. 1 members and 2956 guests.
