[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by minonano View PostI used the patch to nonATV, great, enjoying it, but is the status bar and the navigation bar two seperate entity, and if so anyway of activating the latter, as the ones on playstore dont work as well.
Thanks again and sorry for bothering you.
Originally posted by izzy1971 View Posttillaz87 do you have the reverse script that install TWRP with the terminal apk and the 1 script file. but this time i need to put back the original recovery from 7.1.2 that was in 705NO build. the OTA no longer works since TWRP is installed. so i need to uninstall the TWRP
Code:dd if=/sdcard/recovery.img of=/dev/block/recovery
Originally posted by tillaz87 View Post
Just put stock beelink recovery.img on sdcard (internal) then in terminal enter this
Guest
tillaz87 Is there a solution to get Netflix running? i all times get the error Netflix Error UI-800-3
Tried also different roms and only rom that is working with netflix is stock rom and from superceleron.
As i know he had to edit the netflix apk file (signature), dont know much about it
Originally posted by RyperX View Posttillaz87 Is there a solution to get Netflix running? i all times get the error Netflix Error UI-800-3
that's what "Error UI-800-3" is. Using the standard Netflix app should work fine but limited to SD quality
Links here
Guest
There are currently 3272 users online. 0 members and 3272 guests.
