Updated & Probably final release.. 96 is the latest, all older versions are there also..
Recant Fixes:
Re-based on less buggy older vorke release
codec config fixes
AP6335 & AP4356 WiFi+BT fully supported
Binary cleanup
Performance tweaked again
Fix some freezing issues with 4k h265
Gapps updated
And probably more.. forgot to take notes to busy
Awesome, thanks for your work! BTW, which you recomend SPMC or FTMC? I had some problems with hardware accelaration on H265 with spmc (no video,only sound) and on FTMC (it crashes immediately).
No idea I only tested native playback from es file explorer with this 4096px × 1720px "tos-4096x1720-tiles"
as its where I noticed the freezing. but that's fixed now
as its where I noticed the freezing. Only ever used kodi so no idea about the forks
Ohh okay. There is a bug I think, on the audio option > digital audio when you select auto the app crashes, no big deal. But if I'm connected to a tv trough HDMI should I chose PCM or HDMI?
Hi tillaz, i flash your rom and mycanal works fine without drm L1 it's not normal.
with the atv rom of magendanz and superceleron it don't play.
i have a R-tv box S10 with your last release.
I don't understand why
ok i wish there was normal version as well (not ATV)
All I can suggest is flashing the standard Gapps package over this, it might get you close enough.
I doubt I will be working on anything for at least two month now because of work commitments. If 8.0 is available for s912 by then I might start up again.
