The market should have a "kill all app widget" but no developer would recommend them.
[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tillaz87 View Post
I wouldn't worry about doing that, its a bad habit. Android does it for you when needed, so should really only do it manually when an app has a problem.
Thanks for the rom, I have ultimate box with serial G912, I'm ready to install but there is no info about flashing at the first post. I have the usb burning tool and MULTI_Z6BASED_ATV96.img file (i suppose it is the latest) . Should i flash this with the tool or through terminal app? if i have to use burning tool, which boxes should i tick? thanks.
Originally posted by Panzer81 View Post
I try with the nav bar and it give and the UI crash.
Originally posted by Venomz View PostI'm ready to install but there is no info about flashing at the first post..
(Download ~> ARCHIVE) Flash Burn Package With Amlogic USB Burning Tool v2.0.8 or BootcardMaker v2.0.0.2
Use default settings
Originally posted by Panzer81 View PostHow can I do the logcat?If you're experiencing issues with an app or custom ROM and would like to report your problem to the developer, there's no better way to do it than by capturing a logcat. Android keeps track of all the commands that have been executed by various apps and services, which means that when something goes wrong, the error is clearly shown in this so-called logcat.
attach logcat
From first post
I try another rom (the nexus NOATV by megadenz) and same problem with amazon app shop. I also try romflix (a kodi based frontend emulator) and with ATV v8 by tilaz perfectly work, but with the others 2 roms (v96 no ATV by Tillaz and Nexus by megadanz) doesn't work. Is probably an issue with the vorke firmware?
Originally posted by Panzer81 View PostI try another rom (the nexus NOATV by megadenz) and same problem with amazon app shop. I also try romflix (a kodi based frontend emulator) and with ATV v8 by tilaz perfectly work, but with the others 2 roms (v96 no ATV by Tillaz and Nexus by megadanz) doesn't work. Is probably an issue with the vorke firmware?
Thanks tillaz87, i successfully updated the device. A quick question. I need to put some files from my pc to the beelink, but my pc doesn't recognize the box as a device. I'm using the same cable i updated. any ideas?Last edited by tillaz87; 08 March 2018, 11:57.
Based on diff firmware, I don't use any of the above so you would have to just to try and tell me, v9 has kodi fixes so I would wait and try that over v8
Unreleased V9:- ATV PackageInstaller View
- New soft power menu (no longer needs root)
- Gapps updated
- Performance better tuned after long testing
- Added missing atv fonts
- Sign in can now be skipped
- ATV video + audio Codec config files
- Amlogic codec + other library perm fixes
- Play games removed from system, its updated to frequently (Data has more space with repartition)
Where i can download the v9 archive ?
Kind regards
Originally posted by tillaz87For people who want to convert to non ATV
Patch updated- Add option to display settings to enable/disable nav bar
This wipes your data
Static items like this and status bar cause burn in, so I try to avoid them.
Vorke Z6 here when shutdownin the tv-box it don't shutdown completely always to standby mode
sorry for english hope you understand me
Originally posted by JoseM View Post
the keyboard don't work when using mouse only works for remote control
Are you using the potion from holding power button or from the launcher? Do both do this? This dont happen on GT1
There are currently 1571 users online. 1 members and 1570 guests.
