[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
    Originally posted by tillaz87 View Post
    That post is from 2017 only v10+ are in the archive all the beelink stuff was deleted
    The version 9 is the latest version that does not have the RAM bug on GT1 Ultimate
    So if you still have the archive I would be grateful if you could give us a link to download it
    OR if another user has this version and can put a link to it would be top
    Regards
      tillaz87 can i change sytem interface somehow (system ui always error system ui stopped working i can't view the apps that are running in the background (using nav bar)
        Originally posted by sharkange View Post
        Hello tillaz87
        Where i can download the v9 archive ?
        Kind regards
        here is a link
          The nonATV patch isn't really supported not sure when or if I will get around to it right now
            tillaz87 which is the most recent version? 10.1 or 96? For some reason, I have 10.1 but I see that on Mega, version 96 has the most recent date. Please always be updating us on the most recent file like you used to do with the previous ROM which has V1, v2,... V6 and so on. Thanks for your continued support for this device.
              Highest number is always the latest 96 is kind of final release for now as I dont have the time
                Originally posted by kole View Post
                here is a link
                thank you very much kole
                  just to tell you I have the same problem, it's a pity because the rom is great
                    here is a link
                    tillaz87, I believe this is the OTA not an image, I also would like to play with v9 because I also have a GT1 Ultimate
                      The keyboard is for ATV it don't support mouse. So you would need to sideload different one like Gboard or Fleksy
                      problem solved thanks
                      Are you using the potion from holding power button or from the launcher? Do both do this? This dont happen on GT1
                      i tried both i think that's it because LCD display and all vorke hardware codes are removed right
                        what if i remove system ui completely and install other one (from other firmware) may it work
                          if the framework-res.apk has same public.xml as this, it would work properly, but I don't think its systemUI what is the problem.
                          Try using stock framework-res.apk and build.prop and let me know
                            Just compared the new vorke firmware to the version before it, and they are identical.. other than the ota app and kernel
                              Then the 96 is the latest version we have to install ?
                                I suppose
