[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by Samekas View PostFrom Germany shipping that's a nice deal,but on mi4 from China plus tax duty, or is there any shipping method to avoid that?
https://www.gearbest.com/tv-box-mini...056.html?wid=4
G-W-4, G-W-16, G-W-5 are all EU Warehouse options
Originally posted by tillaz87 View Post
I've never had to pay customs using the standard shipping to uk from china. just make sure you use paypal and avoid the Chinese versions
Originally posted by Samekas View PostThere is only Chinese version atm for the mi4, just checked the specs and they use both same gpu so hardware acceleration would be the same performance on kodi ,since hardware acceleration uses the gpu .
Only reason against the mi4 is it lacks hardware decoding support for VP9 which YouTube uses. the older international version has VP9
What do you think about this box https://m.gearbest.com/tv-box/pp_1013038.html?wid=89 ? It supports Netflix 1080P but not 4K I think.
Has L1 and TV OS
https://www.gearbest.com/tv-box/pp_799407.htmlLast edited by tillaz87; 06 March 2018, 22:48.
Originally posted by minixfreak View Postis there anyway to add working clock for t95U pro?
On another box modded 6.0.1 firmware thread, the stock launcher was used to replace the launcher on the custom rom. On another thread on custom firmware, the framework was based on a firmware never used on the clock display boxes, so no option unless you know how to modify framework.
Originally posted by craser View Posthello tv box gt1 ultimate 3gb ddr4 Wi-Fi 9377 version 707 with v9 installed. can I install the new version? or I would have ram problems
2GB RAM issue is 70D0 only which is ap6255
Originally posted by Panzer81 View PostInstalled with no ATV, everything works fine, but I've a problem with amazon app store. I make the log in an then it freeze. On previos version of rom it works (with ATV)
Originally posted by minixfreak View Postis there anyway to add working clock for t95U pro?Originally posted by X92-2GB View Post
there are a couple of threads on it, but i think it is based on framework and the launcher used.
Its a dead end really wouldn't be worth the hassle much easier to just make / use a rom for that deviceLast edited by tillaz87; 06 March 2018, 22:52.
What about with ATV on latest, does it work?
Another question. How can I see the apps on background? With the v8 holding twice home button I can see them. With this version with no ATV it doesn't work. Is there an app on play store?
I don't know, I didn't try. Can anyone try?
There are currently 1556 users online. 0 members and 1556 guests.
