[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by OCit View Post
Originally posted by TigTex View Post
That's why I've asked for his github or source code, so that I can take a look and solve those issues by myself and maybe he would accept the patches. Unfortunately, most guys don't share their sources so I do my best and tell if something is not working correctly. Of course I'm grateful for their work!
You should also know, if you have any experience of working with android that most of these ROM on freaktab are not built from source by us, as its rarely provided by the Chinese. Again though, the first post clearly says its based on stock so asking for github / source makes no sense.
We just decompile the rom and start debugging and patching, recompiling etc..
Sorry if it sounds like i'm having a go at you.. but its a bit annoying making out I'm not sharing source, because of your misunderstanding.
I actually post near every fix on here for others to use elsewhere.Last edited by tillaz87; 25 February 2018, 19:47.
Originally posted by tillaz87 View Post
try this https://www.dropbox.com/s/u9kq31cxm8...5WIFI.zip?dl=0
I have corrected this from dmesg
Code:[ 23.781518@1] dhdsdio_download_code_file: Open firmware file failed /etc/wifi/6335/fw_bcm4339a0_ag.bin.bin [ 23.790551@1] _dhdsdio_download_firmware: dongle image file download failed [ 23.797512@1] dhd_bus_devreset Failed to download binary to the dongle
Originally posted by CheckMate View Post
It solved a part of the problem, now I can see the wifi but when I try to connect, it says : couldn’t Find network...
reboot then try connecting then get me dmesg.txt will have a look
I will try your previous file
Also try this https://www.dropbox.com/s/xd3dclen3sue7b4/6335.zip?dl=0
During the install in TWRP, I noticed a line in red : unknow command
It cancelled the available wifi
just ignore that unknow command, try this https://www.dropbox.com/s/uzqleflmcx...I6335.zip?dl=0
No change, still no available network
that's odd, this? https://www.dropbox.com/s/uthca8a9la...I6335.zip?dl=0
Many thanks to you for trying
last one for now, hopefully it works https://www.dropbox.com/s/xbt5o1imox...I_FIX.zip?dl=0Thanks.
Print on my wi-fi module is SM63350303 IT-A3
There are currently 2145 users online. 2 members and 2143 guests.
