That info was me just saying why, since people might like to know.
[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by X92-2GB View PostI finally got an order for a Mecool M8S Pro 2GB--16GB. This time I hope my $38 does become fruitful. - Gosh, for the longest time I feel like a lurker with very little to offer, so once I get my hands on my box, I hope to be a non lurker. Ha! - None the less I expect to use ethernet only connection for bidirectional and speedy sharing and streaming.
Originally posted by X92-2GB View PostAlso I hold the strong belief to only use wifi on portable devices only. Only if my neighbors were so smart. They have eaten up all 2.4ghz band with overlapping smart devices that should have been wired. They don't see they are creating their own downfall with best signals and speeds. What the hay, they pay for 1gb links so they can afford to be wasteful with their connectivity.
Originally posted by X92-2GB View PostNow only if i can change my account name from X92-2GB to M8SP-16
Originally posted by Novato View Post
The Mecool M8S Pro box is a great deal, and for $ 38 it was very cheap. If you have never had a box with the Amlogic S912 you will notice the difference in performance, it is very fast but it warms up like a volcano, so if you want to let go of the beauty cut the hood of your Ferrari and install a fan 30x30x10 5V. The Wi-Fi is not very good anyway, the network cable will leave things faster.
So I just gave up and bought a M8S Pro Mini C, since it is a 2018 model.
I don't think I will get it in the mail. The seller soon changed the listing by incrementing the amount available and upped the price to $60.00. Seems like TV Box sellers are cut throat on US buyers. I have seen many boxes have up to $10.00 more additional cost when you select a US plug version. Screw them!
Thanks for this rom !
I just want to know of it’s possible to get the official Netflix app for Android TV throught the Play store ?
I’ve installed the apk but it’s not working (error ui-800-3).
I’ve installer the « Mobile apk » and this one is working but it’s not the best for the tv.
Unfortunately these Boxes do not have enough DRM for HD playback.
They have the same DRM as this custom ROM. I would have gotten a L version, but i plan on using this ROM so it would kill L1 once I flash it. Any who, the only difference between the mini and mini C is that the C is 100mbps not 1gbps. Though I can probably swap out the ethernet chip with a RTL8211F as long as they are the share the same main board, so I can have a newer version 706, 707 than the older 603 pro mini.
For now is impossible, but who knows after a while someone can get the flash in the participation that gets the DRM keys successfully.
For sure, how would you lose your DRM permissions in any way. That's good because you got a Box that really hosted it.
also its very easy to wipe L1 keys on amlogic with burn tool if you select force erase all.. I done this on the PRO L box
Originally posted by tillaz87 View Post
keys are unique to each boxs serial number, so not that easy unfortunately.
This box only has widevine L3 library's but I'm sure it could support a L1 box with some changes,
Originally posted by Novato View PostMy hope is that one day it would be possible to replicate this key to other devices, if Mecool is achieving this (I believe they are not paying for authorization) then it should not be impossible to take this to other models.
Mecool is doing it legit I would imagine, same as xiaomi, as far as I can see you don't have to pay google to included widevine..
but rather pass their certification test http://www.widevine.com/
There are currently 3538 users online. 0 members and 3538 guests.
