[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tillaz87 View Post
this is android TV so the build.prop stuff needs to be for TV device or others stuff is messed up.
try this.. Flash in recovery Patch1.zip Wipe data factory reset after flashing.. best way
I added the last two parts it was missing from MI BOX build.prop, reason it was not originally included was because it was continuously downloading the beta update in background for that device then failing. This now uses info from no beta so hopefully the above dose not happen.
Did this patch solve the certification problem? I also want to use DSTV now, but am stuck on an earlier version of the app. H96 Pro 3Gb/16Gb
Originally posted by Nexus_ZA View Post
Hi
if you could try 10.6/5/4/3 and find it working I would look into it
Originally posted by craser View PostI just flashato the rom 10.7 is applied to your patch: the problems remain USB camera not fixed I reboot the box with Wi-Fi that no longer works. 4k resolution with Kodi, spmc black screen, I am forced to lower the resolution to 1080 60p and it shows well.
Has anyone tried different roms? I can conclude that V10.6 and V10.7 both give black screen on 4k, and limits the refresh rate to 30Hz when selecting 2160p in SPMC, FTMC and CEMC
Are you sure your TV is hdmi 2.0? as 1.4 is limited to 4k@30hz
That must be something with the apps or even your TV as 4k@60hz works fine on my Samsung TV and Phillips TV using Kodi / YouTube / Mx player
On stock firmware it works 4k@60HZ
On this FW it limits the refresh rate to 30Hz when I try to set it.
The problem was the stuttering of kodi most firmwares, but I installed MyGica MC 17.1 which works almost perfect. Just minor stutters.
I'm not complaining at all, as I do LOVE your ROM. Just stating a problem.
Just to add... Kodi performance is much better on your ROM then any other Rom that I have tested to date.
H96 Pro 3Gb/16Gb DDR3
EDIT:
I think the reason for the black screen is because of the refresh rate limitation?
4k@60Hz works fine for me too on kodi, Mx player and VLC, but the problem lies with all the media centres using AMCODEC like SPMC, FTMC and CEMC
EDIT:
I've only ever used Kodi and changes where actually made for amcodec to be supported that people had asked for and reported working, sure people mentioned another fork as well that worked good?
With Kodi you need to enable amcodec from Kodi settings but I can't remember exactly how as I moved away from using it long ago, should be the same for the forks.
Maybe someone else who uses these apps can help?
No worries, I know your not complaining. I'm just going off the top of my head as I no longer use the box anymore.
The problem is not with the AMCODEC itself. When I get a file to play with AMCODEC enabled, it plays flawlessly.
The problem is with selecting the output resolution and refresh rate.
When I go into SPMC, CEMC or FTMC, it starts up and then I get a black screen.
Then I press the power button to let it sleep.
Press it again and the box is on and in SPMC
When I check the output resolution, it is on 720p@60Hz
When I change the output resolution to 4k I get a black screen again.
sleep cycle again and it asks me to save settings - yes.
with 4k it limits refresh rate to 30Hz.
Again it is not an HDMI problem as I get 4k@60Hz on other Roms.
Every time with startup of one of these programs I get black screen.
Kodi 17 playback is good, but just stutters enouph to be irritating.
Anyone else has this problem?
Just to clarify....
This ROM has colour space settings unlike beelink based rom it might be that all I can think of. If I get time I will test with those apps on weekend
There are currently 1778 users online. 0 members and 1778 guests.
