[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by sre92170 View PostThanks Magendanz,
Do you think Meccol M8S Pro L is nearly the same as Beelink GT1 (not ultimate) same DDR3, q20x motherboard ... many thanks.
My question is in fact about flashing this firmware built for Beelink GT1 and Alfawise S92 on M8S Pro L (LB version) because, this firmware transform the GT1 and S92 as a Mibox 3 for applications such as Molotov or Mycanal in France. When i try to use Mycanal on M8S Pro L with other nexus ROM, those app don't work. Many thanks for your help
Par contre faut essayer de flasher ta box. Tu seras le premier ? flasher une Mecool
Guest
Successful work, first thank you tillaz87. Had no problems by flashing my A912 (Burning Tool 2.17 + ATV 10.7) and root. Later in some steps Magisk 18.1 Update and the BT-Fix. Airmouse and gamepad work.
A few more questions:
1. Is it possible with for example Titanium Backup to freeze the process with the recommendations on the homescreen?
2. Maybe the voice search?
3. Can I integrate my own background image?
Greetings from Germany
Hello, I have a tanix tx9 pro and I installed this rom thru this post
This topic is about adapting the [ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate) made by tillaz87 to work on the Tanix TX9 Pro /
I'm encountering some issue :
- When I m trying to download files into an external hard drive, the download speed are slow 10mb/s instead of 20mb/s (internal storage). Are you encountering the same issue?
- When the devise is in stand by mode, the devise is hot. So I need to shutdown the devise every time.
- still having freeze on video playing with all player (Kodi, vlc) => need to use Coreelec.
The rom is very smooth and stable and I like it very much. Thanks for your work
I'm able to flash this rom through USB Burning tool and the first boot it goes normally. I configure everything in Android but after the next reboot it just doesn't start. It doesn't show any image on the screen, like completely dead..
I repeated the process, flash the rom again, connect it to the TV, first boot goes normal but after the second reboot, it goes dead again...
I can I do to fix this?
SN: G912GSHG0051 32GB
There are currently 4505 users online. 1 members and 4504 guests.
