[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tillaz87 View Post
That's interesting it looks like I have some how removed the qca9377 bluetooth files by mistake around v10.3/4 this is why my original zip patch stopped working..
must of been when I was adding the additional AP6533 drivers. i'm going to update to add that back
Originally posted by Clayman_32 View PostHi, I have ALFAWISE KP-810-21T controller , it's great for controlling box (various programs, settings , Kodi, Terrarium etc.), all working but I have problem for controlling games. For example in Real Racing 3 or Asphalt 8 the directional keys dosen't work (original remote directionals keys works), what shoud I do to making it works?Terrarium TV App Download For Android, iOS (iPhone & iPad), PC/Laptop. Install Terrarium-TV APK updated version to watch TV shows & movies for free online.
Originally posted by mft4 View PostI have the gt1 standard s/n g912, I would love to install this firmware but I am still on android 6 and he links to the official beelink firmware to update to android 7 are all down, Please help.
Hey tillaz87 , about mapping the keys of my Air Mouse, yesterday was a success, but soon after I faced a series of errors and the remote control stopped working a few times.
I was editing the file "Vendor_2319_Product_0010.kl" responsible for the Air Mouse, but nothing made the screen capture work again.
After many attempts I understood that this file could not be what dictated the rules in my Air Mouse, there I tried with "Generic.kl" and it worked. Noob suffers. lol
Now that I know where to edit, I'd like to know if it's possible to map to APPs. For example, Key 62 NETFLIX_APP, Key 63 SIDELOAD_APPS. It is possible?
Originally posted by Byjaps View PostCan not create folders or write files to pens and usb disks ... I think it was already mentioned here ... is there any solution to this?
This a completely new rom you just download the rom an burn the imageLast edited by tillaz87; 11 April 2018, 18:26.
Originally posted by Novato View PostHey tillaz87 , about mapping the keys of my Air Mouse, yesterday was a success, but soon after I faced a series of errors and the remote control stopped working a few times.
You should read the link on first post it talks all about making .kl for remote and gamepad and editing them.
If you look at the 0001.kl for the sock IR remote you will see some custom action I added at the bottom for launching app drawer, Kodi, youtube etc
These are hard coded in services.jar and framework-res so add more isn't that easy
Your not supposed to use that generic.kl as that is what's used globally when the system can't find a .kl file for your device. If you change that other devices without .kl could be messed up
Thanks for replying again, I've been seeing here and I realized that it was not a good option to change the file "generic.kl", however the seeing that the file "Vendor_2319_Product_0010.kl" "half ghost, even if I delete it, and then go to the "Gamepad Test" app and take the test, it will still be labeled "Vendor_2319_Product_0010.kl still runs there, but not in the" system / usr / layout "folder, so I did not know where to go to run Generic .kl "and it worked. I replaced the "65 F7" key to Print function on the blue Air Mouse button. Anyway I'm going to leave that aside.
Did you set correct permission for the .kl you made?
Did you use the command from terminal to make sure
Vendor_2319_Product_0010 is the correct ID for the remote?
Also what remote are you using?
There are currently 3214 users online. 0 members and 3214 guests.
