[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Hello. I made a clean install of the rom and everything works great except that when i use KODI I don't have DTS-HD and DD+. Only Dolby 5.1 and DTS. Before I was using Magendanz 's 7.1.2 android tv rom and everything was working OK. I am using exactly the same KODI setup (backup and restore settings)
Can someone help please?
EDIT: under KODI --> settings/system Audio passthrough, not all options are available (like DTS-HD)...Last edited by livadaki; 18 February 2018, 20:16.
Originally posted by Don_Pachuco View PostSo, would I need to flash the stock firmware first, then go back to Superceleron ROM? Every time I try to flash back to that ROM, I get an error in USB Tool. Do I need to leave both boxes checked to erase flash and bootloader?
Originally posted by livadaki View PostHello. I made a clean install of the rom and everything works great except that when i use KODI I don't have DTS-HD and DD+. Only Dolby 5.1 and DTS. Before I was using Magendanz 's 7.1.2 android tv rom and everything was working OK. I am using exactly the same KODI setup (backup and restore settings)
Originally posted by Copper View PostHi,
Very nice job tilliaz. i have one problem, i cannot install a french azerty keyboard. I have installed clavier physique azerty.apk and it will not work. with a original stock rom it will be ok.
And chose in keyboard configuration "clavier physique azerty"
And all it's Ok , works fineAttached Files
Hello I installed the latest updates for my gt1 ultimate ax12 I started with the latest 20180119 [ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1). But despite a nice interface I still have concerns about the sound dolby or dts that are not decoded when I use plex or netflix, by cons if I read a video file (mkv) directly it works. So I installed the latest v10 [ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard + Ultimate) Same problem. On this rom it worked with the v8 Do you have a solution (settings) or should I go back to v8 In addition I must reactivate the wifi at each restart of the gt1 Thank you for your answer Charles
Are you thinking about my little problem?
I just tested a version libreelec (kodi) that works perfectly with this box (wifi stable, bluetooth, sound dts hd etc) with plex
I would like to have the same thing under android if it is possible.
Are new updates planned?
In any case, thank you for the work you do
Charles
There are currently 1729 users online. 1 members and 1728 guests.
