[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
[QUOTE=tillaz87;n708537]Originally posted by OCit View Post
Originally posted by SocksKodi View PostHey tillaz do we have this "Underlying OEM firmware now includes settings for Auto Framerate" on this rom? Because on my tv Kodi needs to be able to do this for smooth playback. I think I might try magendaz last version to see if there is any difference
Kodi is crap on amlogic 7.x this update came with 60fps issues on YouTube that I noticed straight away so not surprised if it's messing with Kodi
the 6.0.1 releases are better for video playback for me
Originally posted by SocksKodi View PostThe problem is that my TV is old so I need kodi to auto refresh framerate and with this ROM the mediacodec from kodi doesn't work that well, only amcodec but that is only available in spmc but spmc is jarvis and my build is Krypton so I think I'll go with dualboot with libreelec probably
https://quickfileshare.org/39x/kodi-...rmeabi-v7a.apk
Or you can get spmc 17 krypton here (17.6a2)
Which is alpha build or beta not sure
Originally posted by tillaz87 View Post
Have you tried this Kodi fork
I'll try the other one
I get no subtitles on SPMC with amcodec (know issue)
I'll try the other oneBuild is also worth a try2017-12-13 20:15 76M
Have you tried on stock are the subtitles still not working? Some stuff for subtitles was removed that I though was part of the media player app
Originally posted by SocksKodi View PostIt's a known issue on github when you have amcodec enabled you get no subtitles. I don't think it has to do with the rom but I might try Stock, Magendaz and your and test. Lot of work tho. I can try that version...
Ok... I just found out the stupidest thing. On display settings and resolution there is an option that says auto best resolution or something like that and I thought ok... It was 1080p24Hz and the interface was laggy. Out of curiosity I changed to 1080i60Hz and voila. Everything is perfect. Going to try kodi now.
There are currently 2753 users online. 2 members and 2751 guests.
