[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tillaz87 View Post
try this the 2gb dtb has ram config for 3gb [ATTACH]n708106[/ATTACH] flash in recovery
this might actually only work in a burn image though like when i re-partitioned the system, let me know 706D only
No luck.
Saw *** Start *** and "Done.".
There was the message
E: [] Unknown Command
Which was show when trying to show the return value
After the flash the box powered off and didn't reboot - no light on the front. Pulled the power cord and put it back in, light on but still didn't boot.
Will flash back to V10
ILast edited by Winno; 10 February 2018, 13:38.
Originally posted by Winno View Post
No luck.
as this bug is having it set as 2gb at boot
I can test my self with 1gb config actually will see if I can get my box locked to 1gb ram then should know if it's just needs done with burn in mage.
Might need done with a burn image like the system re-partition as the ram would also need to be re-partitioned
As you can see from my multiple edits I'm pissing in the wind a bit with this as I haven't done anything with Android before.
Can you share some insights on the tools you use? Would be good to be a little self sufficient.
Do you know if the new firmware GT1_ULTIMATE_3GB_32G - GT1_707D0_AP6255 have the same problem (http://www.bee-link.com/Beelink-28438-1-1.html)
I want to go on your Rom Android TV but as usual, i prepare a rollback because there is so problem on doing this (brick, lag, problem...)
By the way, thank you for all your work and the ADB over Ethernet/wifi tip because i was stuck on it
Cheers
Originally posted by Alexei95 View Post
Hey tillaz87
Cheers
Good idea...
3GB code 0xbff00000 which is hex for 3220176896
Code:memory@00000000 { device_type = "memory"; linux,usable-memory = <0x0 0x100000 0x0 0xbff00000>; };
2GB code 0x7ff00000 which is hex for 2146435072
Code:memory@00000000 { device_type = "memory"; linux,usable-memory = <0x0 0x100000 0x0 0x7ff00000>; };
Hello I installed the latest updates for my gt1 ultimate ax12 I started with the latest 20180119 [ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1). But despite a nice interface I still have concerns about the sound dolby or dts that are not decoded when I use plex or netflix, by cons if I read a video file (mkv) directly it works. So I installed the latest v10 [ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard + Ultimate) Same problem. On this rom it worked with the v8 Do you have a solution (settings) or should I go back to v8 In addition I must reactivate the wifi at each restart of the gt1 Thank you for your answer Charles
No luck with this any change to ram size in the dtb wont boot even with burn image
Bugger!
I did notice the DTB in your patch is about 10K smaller than the ones I extracted.
Fancy trying with the DTB from libreelec? https://kszaq.libreelec.tv/s912/8.2/...Gbit_Ethernet/ these are also 10K larger
Bugger!
Bugger!
There are currently 3470 users online. 0 members and 3470 guests.
