[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tillaz87 View Post
That wont be to often.
I see new hardware from these Chinese OEM coming very soon with 8.0 as the selling point, they then forget about z6 like the others before it.
yes any trace of it
- can't see my gamepad in /proc/bus/input/devices
- can't insmod xpad.ko renamed to xpad2.ko : dmesg tells me xpad.ko already loaded (like before renaming)
-> Kernel patching is my only solution...
I just root with magesk or SuperSU then use ES File Explorer
Originally posted by mperreir View Post
I did not want to install ES File Explorer because I remembered that it was not that good now (it used to be great but ads and other crappy things were added). Anyway, once rooted, it works (but I'm still asked to allow write permissions each time I want to write to SD, even it works without those permissions) and is not that crapy on Android TV.
I simply run rant antutu benchmark for curiosity after firmware installation. Probably my and others 706D version of GT1 have some different components that allow vorke firmware to run 3D. Some screenshots:You may only view thumbnails in this gallery. This gallery has 5 photos.5 Photos
[QUOTE=Clayman_32;n709105]
Anyway can you run it on this rom and tell me if the refinery test completes more than once? this part of the test does not run on stock as its only OpenGL3.0
So your score should be around 55,000 on this
with refinery test completing you should have similar score to this
Post some screenshots when I can.Last edited by Clayman_32; 15 February 2018, 17:47.
Originally posted by X92-2GB View PostI use the KitKat version of Solid Explorer, i think it is still available as classic. Used ES long ago when I first had Jellybean, did not like it as much as solid.
Originally posted by Copper View Posti'm not using a sd card but usb burning tools ans i receive a msg for usb error...) at this time.
There are currently 5160 users online. 0 members and 5160 guests.
