[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
    Originally posted by tillaz87 View Post
    could you tell me if just deleting /system/vendor/lib/libbt-vendor.so fixes it? (after reboot)
    No, you should delate this file and then rename another one
    /system/vendor/lib/libbt-vendor-qcom.so to /system/vendor/lib/libbt-vendor.so, and after that only reboot.
      And q9377, ap6255 still work? if you could share your changes would be good
      Fixed folders, on boxes from my Russian forum-work all these chips: 4335; 6335;6255; 9377( wifi and Bluetooth) . It does not update through TWRP , I hope You know what to do))) boot no need to change)) I Repeat my request to correct the sound in antutu??
        When installing patch 10.1 from recovery I get error file verofication error (21). How to install it?
          to apply the patch correctly in 10.1, you need to change it in build.prop line ro.build.id=NHG47H on ro.build.id=NHG47L
            There is alredy NHG47L value in this rom. I have changed to H and device did not boot. I flash again v10 and still file verification error. see attachement. Any idea how to solve it? Click image for larger version
              Copy internal (0)
                Copy internal (0)
                first lines are for for device not connected. Then i connect. Real install starts with -- Install...
                  Извините, у меня очень слабый Английский ​​​​​​
                    Originally posted by Clayman_32 View Post
                    Reguarding the problem of showing 2GB of Ram instead of 3GB with Vorke firmware after some research I foud that probably my model of Beelink GT1 Ultimate s/n:A706Dxxxxxxxx have fake ram (2GB is hardware original and 3GB is showing via software on original firmware).
                    How did you find this out are you sure? Not good if true
                    Yeah, I know that but was just wanting to know if vendor/libbt-vendor.so was stopping the other been loaded. Since I have AP6255 it's impossible for me to try stuff my self..
                    I will just make a flashable zip that does the above and add to first post.
                    https://drive.google.com/file/d/1bA8...ew?usp=sharing
                    7 years working with android I should know what to do lol for your problem you need to delete
                    etc/permissions/android.hardware.audio.low_latency.xml
                    if your doing android tv you should just replace that whole folder with mine as they have it filled with crap on stock z6
                    Sounds like your using stock recovery the patch needs flashed with twrp and if your flashing the v10 image (and not stock 707) you should already have twrp
                    That's not true, the zip has no environmental checks
                    There is alredy NHG47L value in this rom. I have changed to H and device did not boot. I flash again v10 and still file verification error. see attachement. Any idea how to solve it? Click image for larger version  Name:	IMG_20180208_184757_1024x576.jpg Views:	2 Size:	140.4 KB ID:	707859
                    Sounds like your flashing stock 707 rather than the v10 burn image on first post.. as v10 is NHG47H and does not use stock recovery.
                    Show me how you are downloading v10
                      Twrp or stock??
                      I guess stock - from terminal command: reboot recovery then i try to install. When I select in recovery reboot to bootloader device got stucked.
                      What are options to go to twrp?
                        the zip is for v10 you need have flashed that first from first post
                          tillaz87 LOL))))))))) thanks so much. You have made very very very a good firmware. It is fast, light, stable, productive!!!! I slightly redesigned the interface for Russian users. But your Foundation is great. The patch set from TWRP. Thanks for the tip and advice!!!
                          P.S. If You will be interested http://4pda.ru/forum/index.php?showt...ost&p=69918217
                            What's advantage to flash V9 with beelink 707 to V10 with vorke ? Thanks.
                              hmm.... I see my mistake. I've downloaded and flashed VORKE-Z6-20171221-PC.img, interesting this rom works quite well for my GT1 ultimate including pre installed netflix and mirroring. Now I'm downloading real V10
                                Added to first post
                                Bugs:
                                Here is a patch to fix Bluetooth stutter on QC9377 hardware, its based on this info, flash in recovery (DO NOT USE IF AP6255)
