< v21 API: nothing
v21, v22 API: AC3, EAC3 (broken on most firmware, please bug your vendor)
v23: AC3, EAC3, DTS, DTS-HD (if supported, not on the Nexus 5)
v24 (Android N): AC3, EAC3, DTS with the new IEC API, we miss hardware / software to implement dts-hd, truehd
I am currently on 6.0.1 (Beelink ROM) and it does not support any HDMI passthrough on Kodi, but it does support AC3 and EAC3 on Plex android app.
Thx,
V
This is API 25 as its 7.1.2
I stopped using kodi around the time this box got nougat, but have been back testing it and have to admit it feels much slower than last time I tried it..
Which then was 16.1. However I had the exact same experience on the Xbox one X so I've been meaning to go back and test the the older 16.01
But for me in general its just more hassle and much slower to get stuff done in kodi than just using Terrarium TV (with adds removed)
Description:
This is Android TV based on the latest Shiningworth All-in-One firmware (Vorke_Z6-20171221) it supports all variants of the GT1 + other q201 boxes
I have brought back as much AOSP code as possible removing amlogic / vorke stuff that are not appropriate ChangeLog V10 BETA:
System re-partitioned = 1 GB Extra for apps/data
Framework + App Deodexed
Ramdisk cleaned up & fully un-rooted, also removed from settings (root without prompt is a security risk)
All vorke scripts to install bloat / set default settings removed
Beelink remote fully working (Short cuts: Settings, Kodi, Chrome, Youtube)
Add back HDMI CEC settings (vorke removed it)
Fixed antutu and other 2D/3D games that use unity
Audio fixes aimed at antutu but for sure will apply elsewhere
Magisk can now be installed + safetynet will pass no need for any patch/module
Add playstation controller drivers & activate at boot
ATV PackageInstaller view
New soft power menu (root not needed)
Play games removed from system, its updated to frequently
ATV video + audio Codec config files
Improved media playback + lip sync fixed
Amlogic codec + other library perms fixed
Updated Mali GPU driver + OpenGL 3.2 + Android extension pack (vorke use 3.0)
Fixed unrecoverable from sleep after long periods
Burn-in protection enabled (Oled TVs)
framework is now 99% AOSP 7.1.2 N2G47H
Code removed that was sending errors on home button press (linked to removed OEM stuff)
removed code from services for /sys/class/leds/fd628_dev/ (vorke hardware)
removed code from services that blocks play store updating (vorke)
removed code from services that hides app not responding dialog (vorke)
AOSP Ethernet service + wifi-service
Performance + WiFI/BT/Ethernet Improvements
init.d boot script support
Possibly other stuff I forgot about its been a while on this one..
Notes:Latest version of YouTube is bad, turn off auto update in play store so it wont update
or animation stutter will be frequent when returning to home screen + bugs with recommendationsDownload: Flash Burn Package With Amlogic USB Burning Tool v2.0.8 or BootcardMaker v2.0.0.2 Click to buy me a coffee / beer
Going to disappear for a bit now so will check back in a week or so.
I have installed v10 on my GT1 Ultimate G912/9377. Everything is working well, but as usual with Vorke/Tanix firmware on my device Bluetooth audio is broken and start to work only after replacements (with 644 permissions) of 2 files in system/lib and 1 file in system/lib/hw with this files lib.zip .
