[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by pavelgr View PostPlease help ! What is the command i need type in the terminal app ?
My device is Beelink GT1 Ultimate and i dont have sdcard1
My root is - /storage/emulated/0
su
sh /storage/emulated/0/1
Hi Tillaz,
I have a A706 version (GT1 ultimate ); I have installed your last ROM (from a fresh native beelik version)
I tried to install VNC that needs to root it;
with Magisk, it did not want to wirk while the root was OK
with Supersu it works
Now I want to install Linux deploy and I seems impossible as the installation always crashes
An reason linked either to this ROM or to this ugly A706 version ?
Philippe
Originally posted by SocksKodi View Post
How important is it tho?
The score is not important or the highlight, its all about OpenGL 3.2 graphics compatibility working..
which I know by the refinery test actually running/completing in antutu 7.0.2 as this first part only supports OpenGL 3.1+
so it wont even run on stock z6 or beelink as they use OpenGL 3.0
So without this working anything built for 3.1+ wont work and 3.2 is the latest for android and probably highest this GPU will support so.. why not.
Anyway its all sorted now and working.
the problem was my 2GB device simply has not got enough ram (and getting to hot) to complete the whole test constantly. (will complete once after reboot)
this is because its stupidly split in to two apk that both run intense 3D tests that are RAM hungry.. one of them eventually gets killed which ends with a fc
Originally posted by tillaz87 View Post
To me it matters as it adds support for more apps/games plus a bit of future proofing.
Originally posted by kole View PostHello!!!
can we improve the sound SPDIF, enable passthrough bypassing kodi?
with:
Added ViperAudio
Added Dolby Atmos
is it possible?
thank you
No idea about passthrough
Originally posted by lapillo View Post
Tillaz, do you know anything about 3d issues noticed on GT1 ultimate with serial AX12. Currently there is no way to run any 3d games. Is there any chance it will be fixed?
There are currently 1627 users online. 0 members and 1627 guests.
