[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Hello to everyone!!
I want to congratulate the developer for his fine work with this ROM!!
I've installed the V9 over the V8 to my GT1 Ultimate and I'm experiencing some minor issues:
ISSUES:
1. My Bluetooth mouse can't connect (pair) anymore with the TV box. With V8 it was working perfectly. (Mouse: Xiaomi MiMouse)
2. Google photos app (side loaded) doesn't work anymore. It can't load my photos (constantly loading)
Thank you!!
Hello to everyone again!!
I want your opinion and the developers of course about some thing I want for the TV box
1. A torrent client to work with this ROM and to be capable to save to a NAS storage via LAN?
2. A compatible remote controls that will work with this ROM?
I'm looking remotes with the following features:
A) Air Mouse (Gyro)
B) Full keyboard
C) IR Learning
D) Microphone (Google Now search)
Will this remote work with this ROM?
Thank you!!
Originally posted by iliasv82 View Post2. A compatible remote controls that will work with this ROM?
A) Air Mouse (Gyro)
B) Full keyboard
C) IR Learning
Originally posted by tenoce View Post
I have this one, and fulfills all your needs: https://www.aliexpress.com/item/T3-2...639140680.html
Will it be with batteries or rechargeable battery?
Originally posted by craser View Posthello .i have noticed this that the 4k2k resolution is set 2160 420 bit 10 and not 3840. why? could this be the cause of the lag?
2160p = 3840x2160
1080p = 1920x1080
The lag must be on your side as I've not noticed it maybe try a clean install check if you have any apps running constantly in the background
It's more than likely something you installed as I was just back testing this to fix an audio problem on z6 firmware and don't see the above issue.
ISSUES:
Thank you!!
About Google photos etc, If you don't mind paying £1.75 I highly recommend this app for android TV it's the only app I ever felt was worth buying
https://play.google.com/store/apps/d...I4S9gAbDj4W4Cg
Google won't ever give us a native tv app as they believe it would be prone to privacy issues as pictures instantly sync
Originally posted by tillaz87 View Post
Nothing changed with Bluetooth or sync on v9 was a minor update as the main work is been done on z6. maybe try clean install?
Thank you!!
Originally posted by craser View Postthe applications installed are: Chrome 64bit, skype lite and 64bit spmc. I think back to ftmc because amcodec is activated. What do you mean by clean installation? factory reset?
if ts 4k2k@30hz it will lag as its limited to 30fps and if your tv is ony hdmi 1.4 you will be limited to this and in that case its best to use 1080@60hz
There are currently 2000 users online. 0 members and 2000 guests.
