[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Hi, I'm new here and sorry for my English.
I ordered yesterday a Bee link GT1 and I would ask you some questions about this rom.
1) To install the rom you need to have the stock 7.1.2 correct? and follow the steps listed in the first post? It also install the recovery automatically?
2) To return to the stock is enough to flash the stock rom from recovery?
3) Does Gaming Performance Improve?
4) Everything works? are there known bugs? How much free space remains?
Thanks a lot
Originally posted by makavelio View PostAnyone got this working on their box perfect? https://www.gearbest.com/mouse/pp_66720.html
Originally posted by Guus View PostGreat so i can try dirty flash over v6
Originally posted by steja View PostTillaz87,
My GT1 lose resolution options after unroot.
Only 3 modes: 480p,720p,1080p.
I use the 4k60hz, and after unroot its just 1080p max.
And btw,
The service.Bootloader is still 0, dark scenes looks too dark (beelink or amlogic fault anyway)
Think I removed bootvideo, will add it back. that dark screen thing was fixed in 7.0 though I've not seem it since 6.0
Originally posted by Panzer81 View PostHi, I'm new here and sorry for my English.
Thanks a lot
Originally posted by tenoce View Post
I have a similar T3-M, which works just fine. Except 2 function buttons.
select button doesnt work on keyboard for me
I also think his use of the all in one shiningworth firmware makes the general wifi and 3d graphics performance better (41k on Antutu).
Great work, but you should really move from using Beelink firmware
on antutu I was Seeing 40,000 with stock. now 41,600 (2GB variant)
few more things to look at before releasing
Hi, great job tillaz87, I wanted to report 2 bugs and 1 request;
1 - When the GT1 goes into standby, the network connection with the cable does not react until you restart GT1.
2 - The volume of the GT1 does not adjust, on/off is not adjustable.
3 - On the home page there is the power menu with 3 choices, it is possible leave only "Power"? Because i've noticed that in settings, there is the option to chose.
Thanks for the great work
There are currently 2073 users online. 0 members and 2073 guests.
