on post-fs-data insmod /system/lib/mali.ko mali_debug_level=2 mali_shared_mem_size=0x40000000 # ko for dolby vision insmod /system/lib/dovi.ko
[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tillaz87 View PostCode:on post-fs-data insmod /system/lib/mali.ko mali_debug_level=2 mali_shared_mem_size=0x40000000 # ko for dolby vision insmod /system/lib/dovi.ko
Originally posted by tillaz87 View PostUSB Burn tool tip: Plug in the power and USB at the exact same time.. and it connects first time, every time.. no pin needed
Can't believe I just noticed this.. so much easier now!
Now it never works and give an error with bootloader
So I push START first then push reset pin and connect the USB
.......et VOILA ;;; works 100% of time
Philippe
I have downloaded first the stock ROM as per the instruction, then applied the file for Google TV.
The installation itself went super smooth, no problems at all.
Now however I have few major problems
I have tried only with the stock ROM, so clean Android 7, without Google TV patch, and again the same problems
- KODI is not playing normally - buffering for half minute, then plays for about the same time, then again stops for buffering
- Youtube has really terrible lip sync offsetout of sync completely
- I was thinking that I have problem with network, although I am using ehternet, not WiFi, still KODI is shopping, and youtube sucks
- installed speedtest, shows only 9.5MBs on download both on ethernet and WiFi (5GHz)
- testing with phone on WiFi - 44MBs
I don't know what is wrong, but I'm downgrading to Android 6.
The device is Beelink GT1 (not ultimate).
Anyone with problems with Android 7??
Originally posted by muchoz View PostI have downloaded first the stock ROM as per the instruction, then applied the file for Google TV.
I installed Libreelec 8.02 on GT1 and Kodi works like a charm, but with all 7.1.x Roms Kodi is giving me troubles and Youtube is out of sync on most of them.
There are currently 3213 users online. 1 members and 3212 guests.
