[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tillaz87 View Post
Yes
I have rarely seen this happen, but not after unrooting though. rebooting the box always corrects it
Think I removed bootvideo, will add it back. that dark screen thing was fixed in 7.0 though I've not seem it since 6.0
Yes to all, free space is normal for a 16gb device just under 13gb free
I actually had that remote. Will post a guide soon to get these working properly on android it's easy as can use mine as a template
Hi guys. First thanks to tillaz87 for your amazing work. I know this subject have been discussed before but I cannot find any answer to my problem or anyone having the same issue. I have an xbox 360 wired (that's the important bit I believe) controller that doesn't work on this rom. I have other generic gamepads that work perfectly, but the xbox360 just blinks for a while and then turns off. It seems it's not recognized, is it supposed to work out of the box ? Or could it be that only bluetooth pairing is working ?
Second question: I use Molotov for wathcing TV. It doesn't work on this rom, there could be 2 explanations:
- it doesn't work on a rooted device ? then how could i unroot it ?
- it requires some level of google DRM (i forgot the name of the system) that cannot be provided by this rom ?
Anybody managed to get molotov working ?
Many thanks for your answersLast edited by tom-s; 30 November 2017, 09:08.
There are currently 1301 users online. 0 members and 1301 guests.
