[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
I have now added a "reboot recovery" option to the default power menu, which does not require root as its part of framework.
This was kind of needed as been unrooted on TV boxes can be important for a few apps.
now if i could just get the soft power button to just call GlobalActions... would be great.
still unsure what i'm doing going forward though, as in rom base.. they all feel the same in everyday use to me
Originally posted by tillaz87I have now added a "reboot recovery" option to the default power menu, which does not require root as its part of framework.
Originally posted by tillaz87 View PostDescription:
Would highly recommend a clean install with the script for this, but your free to try flashing the zip in recovery without wipe to update (from previous version)
But if you do and see loads of crashing and problems please do a clean install before reporting it to avoid confusion
PackageV7
Script
Terminal- Download the 3 Files above and copy them to the Internal Storage (script is made for internal as the mount is always /sdcard)
- Install the terminal.apk or download one from the market
- Open the terminal app and type the commands below pressing enter after each
Code:[B]su[/B]
Code:[B]sh /sdcard/1[/B]
It's the 1st time I can't install it properly.
Clean 707 IMG ---> terminal installed ---> all in internal storage ---> used the script ---> ATV.
But,- No TWRP (Must clean Cache/Davlik before using it), but "NO SIGNAL" on TV.
- No SuperSU to unroot.
EDIT:
Okay. all WORKS FINE!
had to factory reset again.Last edited by steja; 27 November 2017, 14:23.
Originally posted by tillaz87 View PostJust got a decant looking air mouse but the select button don't work with leanback keyboard ? anyone know of a fix to save me looking???
Sure someone else had this problem and asked if could fix it?
It's because the scan code for most of these air mouse for the select button is 28 which is enter in generic.kl
It's needs to be DPAD_CENTER
I can post a guide on how to make keylayout for these
Here is the remote i picked up, it seems very good now I made keyayout..
https://www.geekbuying.com/item/H1-2...ck-386325.html
here is the keylayout for this remote, works with any android (needs extracted) Vendor_0c45_Product_800a.zip
it goes in -> system/usr/keylayout (set permissions, reboot)
I've found 2 small bugs of V6 that i don't know if are there also in V7...
1st is that if i use "suspend" option when i start the box again, I've no connection (I'm on cable lan)
2nd is that each time the box starts is needed to choose the app to use with settings and home even if i set as "always" the choice
There are currently 2240 users online. 1 members and 2239 guests.
