[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
    First , tillaz87 and Magendanz
    I can't thank you enough for all your support hard work and commitment to support the vaious android box.
    I have flashed a number of your rom for GT1 beelink hardware. First of all when following instructions as directed, everything works as expected.
    I am not a fan of the TVbox version patch you modified, the interface is pretty but don't care for the playstore and having to backload applications like esfilexporer to install stuff that are not on playstore.
    like many other I run into the DRM issue. I am using ATT U-verse.apk to stream live tv but unfortunately it does not stream due to DRM ( works fine on unroot device I own Samsung s5, note4,6..)
    I am planning on testing the mod you link a few page back that uses universal safetynet to see if it works.
    Any other thoughs and idea ? to make the GT1 look legit unroot without the need to have special Netflix, directtv... app ?
    I guess what make these box so different from a Samsung tablet where the ATT uverse app work flawlessly?? I and others just want to get there
    Thanks again for your support
      For me I prefer android TV on these boxes as all the apps on that market work with remote or gamepad. But guess that's the good thing about android, each to their own.
      For TV/Movies i now just use terrarium TV since its got everything and free.. I used to use Netflix and prime util i sold my shield TV and got a box that gets crippled with DRM
      Just doing a factory reset will totally remove the root in this as its systemless, but to be honest it should be undetectable anyway
      reading this it looks like your app might be doing some other device checks
      https://forum.xda-developers.com/and...e-app-t3435180
        [QUOTE=tillaz87;n686741]
        you need to add your new launcher to system/app set permissions then delete leanback launcher
        Ok do you have the apk file to leanback launcher (for rollback) ?
          Chromecast work with your rom ?
            not working on any rom yet, its a bit of a puzzle
              Can you make Netflix (android TV version) to work?
                no it needs widevine L1 DRM which this box does not have.
                this is the box people need for netflix tv with 4k
                China-1 Stock | Buy MECOOL M8S PRO L YouTube 4K Netflix HD Streaming 3GB/16GB Android 7.1 Amlogic S912 KODI 17.3 TV BOX 802.11AC WIFI Bluetooth LAN HDMI - Black online at unbeatable prices. ✓Free Shipping ✓Limited Time Sale ✓Local Warehouses.
                  https://www.geekbuying.com/item/MECO...GB-386123.html
                  But it doesn't have android TV
                    So if we flash the M8S PRO L rom on GT1 beelink device it should work ? will netflix and att-uverse work. ot do we hneed to buy an entire new box ?
                    by theway terraiumtv does not have live tv, so not really a substiture for ATT- uverse.apk which is why i want it to work on the beelink gt1
                      I wanted to test several launchers. After I deleted them all to leave the original one and now at each startup of the Android box asks me if I want to put it by default .. I choose Always but it does not avoid the same message at the next boot, how correct? Thank you
                        hi there - would like to try this but not sure how to proceed.
                        currently running scv2-atv which I think is android 6.0.1, which f/w would I install ?
                        thanks for your time.
                        also twrp is installed, could I still update using the male/male usb cable and the usb burning tool ?
                          as far as i know it does run android TV with latest update, I was looking at the firmware. even picked one up myself
                          Unfortunately not as the widevine L1 keys are factory flashed and not part of the OEM firmware. flashing full images for other boxes might not end well ether.
                          ATT- uverse.apk might work if you spoof the build.prop to be a Samsung, but really need a logcat to know why its not working.
                          clear data for launcher
                          707ON, depending on your WiFi chip which variant, the rest is good to go
                          QC
                          http://www.bee-link.com/forum.php?mo...rby%3Dlastpost
                          AP
                          I will be releasing an update sometime today (uk time)
                            QC
                            AP
                            Thankyou for replying tillaz87.
                            have already tried this using the usb burning tool but only getting to 2% and giving me the Romcode/Initialize DDR/Read initialize status/USB Control setup error everytime, was thinking this could be because of twrp.
                            Thanks for your time mate.
                              QC
                              AP
                              its power failure I think, I had to use pc with usb type 3 laptop was keep doing that
                                Will try later using power lead once box has connected to laptop.
                                Thanks mate.
